Old 09-17-2020, 10:13 AM   #1
DannL
DannL's Avatar
Default Coating the armature . . .
Any thoughts on what product would be suitable to coat the amature of a starter and/or generator (excluding the commutator of course). Polyurethane? Shellac?
Not a Purist.
DannL is offline   Reply With Quote
Old 09-17-2020, 10:19 AM   #2
RTPbee81
RTPbee81's Avatar
Default Re: Coating the amature . . .
Good question... i just ordered a can of
CRC Urethane Seal Coat Viscous Liquid Coating, Red
hope this is the right stuff, it's identified in the Model A Generator book, says to soak in it but I ordered a spray can, Is this going to work or am I asking for Trouble
RTPbee81 is offline   Reply With Quote
Old 09-17-2020, 11:09 AM   #3
Jim Brierley
Default Re: Coating the armature . . .
Should work fine.
Old 09-17-2020, 01:06 PM   #4
fuzes45
Building transformers, dipped coil in Varnish and baked.
Bob F
fuzes45 is offline   Reply With Quote
Old 09-17-2020, 03:01 PM   #5
42merc
42merc's Avatar
Glyptol, made by GE, used in the industry.
Buy at your local electrical supply store.
42merc is offline   Reply With Quote
Old 09-17-2020, 05:13 PM   #6
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by 42merc View Post
Glyptal, made by GE, used in the industry.
X2 on the Glyptol.
Local Grainger stores generally have it too.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-17-2020, 05:59 PM   #7
GPierce
GPierce's Avatar
Yes Glyptol. Have used for years on motor, alternator and starter repairs.
GPierce is offline   Reply With Quote
Old 09-19-2020, 09:40 AM   #8
Joe K
Joe K's Avatar
X4 on the Glyptol.
The power plant I worked at used Glyptol on EVERY motor, both exposed armature windings and the field coils. They claimed it prevented "working" of the wires under magnetic stress, and consequent wear-through of the varnish insulation.
It is a bitch to get off for re-winding, however. By the time you get to that point you're talking a major rebuild anyway.
It is also used a lot on the interior of cast iron motors/transmissions after tanking or blasting. Seals in the errant pieces of sand or grit and makes an interior surface the oil can "slip down on" easily.
https://www.amazon.com/Glyptal-Brush...516BM8VVKG3WC7
Joe K
Shudda kept the horse.
Old 09-19-2020, 09:45 PM   #9
CWPASADENA
CWPASADENA's Avatar
X5 on the Glyptol,
Have used it for a lot longer time than I would like to admit. The first time I used Glyptol was when I was working on Model A's to make a little money for collage. That was 66 years ago. Been using it every since.
Chris W.
CWPASADENA is offline   Reply With Quote
