05-14-2020, 04:14 PM | #1 |
How to mount the piston rings from above?
Hallo und guten Abend,
today when I installing the pistons, the lower oil drainage rings were extremely difficult to thread into the cylinder from above. Even with the help of a piston ring tension band it was not manageable. (Unfortunately, a part of the oil drainage broke off on the 4th cylinder.) What am I doing wrong?
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
05-14-2020, 05:13 PM | #2 |
Re: How to mount the piston rings from above?
First, gap the rings.
Install on the pistons Stagger the ring ends Use a compressor [ or cone] and tap the piston into the cylinder [ make sure clearance is correct] |
05-14-2020, 06:09 PM | #3 |
That is a very strange looking oil control ring. Was that the entire ring ? I have seen spring like parts similar to the pictured part that is only the expander in a three piece oil control ring assembly. I am familiar with the three piece assemblies having a spring expander and two thin scraper rings.
Joe B |
05-14-2020, 10:44 PM | #4 |
That is just the expander or spring portion of the oil ring assembly.
It works with two steel rails, The gaps must be staggered and the ends of the expander must butt and not overlap or it will cause breakage as you have experienced. Bill Last edited by bbrocksr; 05-14-2020 at 10:52 PM. Reason: more info |
05-15-2020, 06:33 AM | #5 |
Ooopps, I mis-read the OP.
Gap the rings Install rings from bottom first/up on pistons. In other words oil ring first. Most oil rings don't need an expander, the others can be put on without an expander but an expander does help. Last edited by Patrick L.; 05-15-2020 at 07:53 AM. |
05-15-2020, 08:24 AM | #6 |
05-15-2020, 10:04 AM | #7 |
Also: oil the rings before putting on the ring compressor and oil the cylinder before installing the pistons.
05-15-2020, 11:37 AM | #8 |
Also the top of the cylinder must have a slight bevel. If it is not there you can put one in place by using a large half-round, fine-cut file. This should have been done when the engine was bored, done by the boring bar.
05-15-2020, 02:04 PM | #9 |
Following up on Jim Brierley's post about the top bore bevel, there is another problem:
Often the bore bevel or chamfer's depth exceeds the thickness of the thin top and bottom parts of that three-piece oil ring assembly. When you tap the piston down through your ring compressor those thin top and bottom sections are freed from the compressor at deck level and expand way up at the top of the bore chamfer. Now you're stuck. I have experienced this quite a few times and my 'fix' was to take a waffled compressor (not the flat band type) and grind the band so the edge of the waffle is 45 degrees and sharp, not the original 90 which made it sit flat on the deck. With that 45 degree edge the compressor seats on the inside edge of the bore chamfer, below deck and permits those thin sections to pass easier. |
05-15-2020, 02:46 PM | #10 |
What helps me when using a band type ring compressor with the two 'straps' is to put the lower 'strap' right over the oil ring, tighten the band, then lightly tap on the strap to encourage the rails to compress fully, and etighten. Then be sure to hold the ring compressor firmly against the block while tapping the piston in.
05-15-2020, 03:21 PM | #11 |
Guten Abend!
Thanks for all the advices. I have now ordered the .6 Hastings piston ring sets by Bratton's parts. I think that attaching an angular chamfer to the top of the engine block places an extreme strain on the head gasket because the combustion pressure creates mechanical and hot contact surfaces Good idea by knocking on the tensioning belt and tighten again. What is a please is a "waffled compressor"?
05-15-2020, 03:34 PM | #12 |
05-15-2020, 04:17 PM | #13 |
Yes, thank you, Mike. It's a piston ring plier. We call that "Zange".
05-19-2020, 06:04 AM | #14 |
Guten Tag.
The new rings arrived yesterday. Hastings look different than the previously assembled ones. The second pressure ring had a lower nose on the outside for additional wiping off of the oil. This is not the case with the new ones, they have only a chamfer at the bottom and inside. In addition, this wafer-thin steel shaft was under the ring. The Hastings didn't have this corrugated ring, so I didn't reassemble the old ones. The scraper rings are also designed differently. At least not so fragile. The assembly of the oil control rings was very difficult with a lot of time over two hours.
