01-03-2020, 03:30 PM | #1 |
turn signals
Just got my Blinkie! wow what a nice unit, If you have converted to 12v neg ground and want a premium column mount turn signal you wont be disappointed, a bit pricey but very high quality made in the USA! Ken
01-03-2020, 03:59 PM | #2 | |
Re: turn signals
This? > https://www.mooneyesusa.com/product-p/aabl200c150.htm
The only thing nice about being imperfect is the joy it brings to others.... "Silver rings, your butt! Them's washers!" "We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969 https://www.youtube.com/watch?v=7NReUd2_0u0 Last edited by petehoovie; 01-05-2020 at 11:53 PM. |
01-04-2020, 11:59 AM | #3 |
Re: turn signals
Yup that's it. Got mine from Hot Rods and custom stuff. it was $100 less than Moon. Ken
01-05-2020, 11:49 AM | #4 |
Re: turn signals
Yes indeedy. That's a nice unit.
01-05-2020, 12:09 PM | #5 |
Re: turn signals
Looks clumsy
01-05-2020, 12:24 PM | #6 |
Re: turn signals
01-06-2020, 07:59 AM | #7 | |
Re: turn signals
You can use the lever from 50' VW Bug or Transporter This great information was found on the net from an unknown source: |
01-06-2020, 08:52 AM | #8 |
Re: turn signals
This is the "Style" switch used throughout England and Europe for many years on many vehicles. NOTE on the lower left and of the gauge cluster.
01-06-2020, 12:11 PM | #9 |
Re: turn signals
OK but doesn't self cancel like the Blinkie or others do by time
41 woodie https://41fordwoodie.weebly.com/ |
01-07-2020, 11:59 AM | #10 |
Re: turn signals
The Blinkie controller should make your wife happy since the turn signal is turned off after a set time.... so she doesn't have to say "do you know your turn signal is still on?" Of course, I reply "I know it's still on, I want it on for the next mile or so"
01-07-2020, 12:35 PM | #11 |
Re: turn signals
The blinkie timer is set so if you do it quick its perfect for lane changes then hold longer for turns as well as always on if you hold brake. Also, the length of it puts the lever at your finger tips with a stock size steering wheel just like your modern car. I think there was a bunch of thought put in the design. Made in USA like our Fords. I do have a VW part in my 34, its a 12v bug horn hidden in original horn housing. Ken
01-07-2020, 06:43 PM | #12 |
Re: turn signals
Very nice looking and nice features , but for $495 , i think I will stick to the $30 universal clamp on style I have always used .
Even at $395 from Hot rods and custom stuff in Escondido , still spendy. |
01-08-2020, 03:55 AM | #13 | |
Re: turn signals
Karl
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me. |
01-09-2020, 02:35 PM | #14 |
Re: turn signals
Unfortunately, the positive ground is a problem for the current design (no pun intended) since the electronics don't like the polarity change. There has been at least one 6 VDC installation but no positive ground solutions that I am aware of. Too bad as the old Ford market demand could be large.
02-02-2020, 07:07 AM | #15 |
Re: turn signals
I have decided on the BOSCH Classic turn-signal switch # 0 341 810 013 with integrated headlight-flasher function (right picture)
I will make a housing similar to the VW assembly. |
02-02-2020, 08:21 AM | #16 |
Re: turn signals
For those who are looking for a different option and one that will work on 6 or 12 v and both + or - ground, below is a great option. I have one and it's perfect.
http://www.turnswitch.com/Turnsignal.htm Terry
02-02-2020, 10:38 AM | #17 | |
Re: turn signals
