Old 04-12-2019, 08:29 PM   #1
woofa.express
woofa.express's Avatar
Default adapting '35 steering box to '28 A
the slop takes the pleasure out of driving or should I say just makes a simple task difficult.
I have a good condition '35 steering box I'd like to adapt. The vertical measurement is a big to fit into the chassis. Has anyone modified the chassis to accommodate same.
all the F100 boxes are near impossible to find so that's not an option. We are R.H.D.
I know many things,
But I don't know everything,
Sometimes I forget things.
And there are times when I have a long memory.
woofa.express is offline   Reply With Quote
Old 04-12-2019, 08:56 PM   #2
Lawrie
Lawrie's Avatar
Default Re: adapting '35 steering box to '28 A
get one of the books from one of the suppliers,on Ford sterring boxes,it show how to fit a later box into the A.
If you can find the book let me know and will look for the one I have
Lawrie
Lawrie is offline   Reply With Quote
Old 04-12-2019, 11:30 PM   #3
Charlie Stephens
A couple of thoughts. I believe you should reduce the size of the steering box mounting pad and leave the chassis alone. Another thought, when is the last time you heard someone say they installed a '35 ford steering box and liked it? Have you ever heard someone say it felt like power steering (a comment often heard in reference to the F100 truck boxes)?
Have you tried placing a "wanted" ad for the RHD F100 box? Have you contacted Randy Gross and asked if he had any?
Charlie Stephens
Old 04-13-2019, 03:30 PM   #4
Charlie Stephens
Did you notice that the '35 started the cross steering (where the steering link goes across the car to the spindle on the opposite side)?
Charlie Stephens
Old 04-13-2019, 05:14 PM   #5
woofa.express
Lawrie[/QUOTE]
Thankyou Lawrie, let me get back to you please. gary
I know many things,
Old 04-13-2019, 05:16 PM   #6
woofa.express
Charlie Stephens
Thankyou Charlie. It is a traditional steering box with pitman and pushrod. gary
I know many things,
Old 04-13-2019, 05:18 PM   #7
woofa.express
Charlie Stephens[/QUOTE]
I did contact one rebuilder in USA but don't recall his name. this fellow had none. thanks, gary
I know many things,
Old 04-13-2019, 05:48 PM   #8
Charlie Stephens
That brings up another question, are you sure it is a '35? I must admit that Ford may have used different suspension in Australia and my information may not be accurate since I am not really into the '35. How about some pictures?
Now for a bit of trivia that you may already know. What I consider the first major improvement after the Model A came in 1937 when the sector shaft was redesigned to replace the gear teeth on the end with a gear mounted in a roller. This roller mounted gear continued through the F100 truck (and probably longer). I am not sure the '35 would give you the improvement you want. See attached.
Charlie Stephens
Old 04-25-2019, 06:01 PM   #9
woofa.express
here it is, the '35 steering box that I'd like to adapt to my 28 Pickup.
I know many things,
Old 04-25-2019, 09:06 PM   #10
28CCPU
28CCPU's Avatar
Try Randy Gross he may be able to help you out
28CCPU is offline   Reply With Quote
Old 04-25-2019, 09:49 PM   #11
Charlie Stephens
The 68 at the beginning of the part number says it is a '36. It is not going to have the roller that I show in Post #8. If it is better than a Model A it is because of leverage. Also note it is cross steering that you are going to have two incorporate into your modification. I wouldn't spend the time on it. What did Randy Gross say when you contacted him?
Charlie Stephens
Old 04-26-2019, 05:38 AM   #12
Dave Slater
Dave Slater's Avatar
Just a thought - Why don't you get Rob Turner to rebuild a 1928 - 1929 steering box for you using a encentric bush and roller needle bearings on the sector. No modifications required to chassis- bolts right in. Rob can also put the nylon steering bits in the front end to make it easier to steer. Dave
Dave Slater is offline   Reply With Quote
Old 04-26-2019, 11:21 AM   #13
Jim Brierley
I've seen a '55-'59 Chevy 1/2 ton Chevy pickup adapted into a Model A. They are recirculating ball boxes, and very easy to steer. Might be worth looking at???
Jim Brierley is offline   Reply With Quote
Old 04-26-2019, 09:57 PM   #14
woofa.express
Hi Dave. I have spoken to Rob in hope that the gemmer box components could be adapted and the answer was no. It seems every one knew that except Gary but when I view the two boxes that was the obvious answer. Also those I ask all say the 28 box will still have much slop regardless of what bearings or bushes I use. the steering is the only thing that distracts from total driving pleasure. It also seems replacing this steering box with a 30 model gemmer is probably the simplest modification, it's just that I have this 35 model on my shelf. I'll give you a call when I get home. cheers, gary
I know many things,
Old 04-26-2019, 10:01 PM   #15
woofa.express
Charlie Stephens
Hi Charlie, yes I did wonder if Randy Gross had any from an imported RHD imported from South America but no he didn't. I can get one from New Zealand and that is probably the way I'll go. thanks Charlie and cheers, gary
I know many things,
Old 04-27-2019, 04:49 AM   #16
Dave Slater
Gary. I have a new RHD sector and a new worm for a 7 tooth steering box and if we use them along with the encentric bush Robert can remove all of the slop in the box and we machine out the sector housing and install needle bearings it will be a lot easier to drive.
Old 04-27-2019, 11:53 PM   #17
woofa.express
thanks for that Dave. I'm in Queensland and will give you a call when I get home. It's a bit silly coming to Queensland when the weather is still warm at home isn't it. cheers, gary
I know many things,
Old 04-28-2019, 03:46 PM   #18
Lawrie
Lawrie's Avatar
Where in QLD are you.
I will look out the book tpday,
also my 28 steers great, like Dave said, machine the shaft make and fit an ecentric bush and its nearly as good as new,
Lawrie
Old 04-28-2019, 04:09 PM   #19
Pete
Pete's Avatar
When you use a cross steering box in a side steering application, you have to have the pitman arm up instead of down or it will steer backwards.
In the later boxes like the 37 to 48 with the roller sector, you can convert them to have the pitman arm down by using 37 Hudson gears. No machining involved.
Old 04-29-2019, 01:47 AM   #20
Lawrie
Lawrie's Avatar
Woofa, the book is called FORD steering, service,repair and modification,
Its by Vern Tardel, one of the let me help you series.
booklet no 1.
lawrie
Thread Tools
Display Modes
