01-24-2015, 11:06 AM | #1 |
Valve Caps (tires)
Did each tire have a valve cap for removing valve or one per vehicle from factory? JS dosen't really say but that spare had one and the others?
www.whidbeymodelaclub.com Last edited by Gary WA; 01-24-2015 at 11:16 AM. |
01-24-2015, 11:58 AM | #2 |
Re: Valve Caps (tires)
01-25-2015, 06:19 PM | #3 |
EXCEPT ACME valve stems... ALL stems on the ground had a full cap and ONLY the spare had the valve remover cap... 1 out of the 5
01-26-2015, 10:18 AM | #4 | |
From The Revised 2011 JS&RG In the general description - "Valve Cap - All valve caps were unpolished nickel plated and had a core remover tip." In the ACME description - "Valve cap - The core remover valve cap was 5/8" tall with a 23/64" diameter base. the upper portion had a slightly larger diameter with an x knurling pattern." Listed on the component chart, All ACME stems used the 301 ACME cap, which is a core tip cap. If there is something I'm missing, could you point me in that direction. |
