Old 11-06-2020, 01:24 PM   #1
mrtexas
mrtexas's Avatar
Default 49 hood ornament
Original plastic piece broke off and was held in by friction. New one is loose. Do I glue it in?
41 woodie https://41fordwoodie.weebly.com/
mrtexas is offline   Reply With Quote
Old 11-06-2020, 04:38 PM   #2
50fordcoupeman
50fordcoupeman's Avatar
Default Re: 49 hood ornament
I used a dab of silicone on mine. That will hold it but you can also get it apart if the need arises. Good luck!
50fordcoupeman is offline   Reply With Quote
Old 11-06-2020, 06:38 PM   #3
mercman from oz
mercman from oz's Avatar
Here is a picture of the clear trim on the hood ornament for your 1949 Ford that has come loose. Hope you have success in making your replacement secure.
Old 11-06-2020, 06:45 PM   #4
mercman from oz
I think that a lot of people assume that the Hood Ornaments on 1949 and 1950 Fords are identical, but they are not. Here is a comparison picture of the 1949 and 1950 Ford Hood Ornaments.
Old 11-06-2020, 07:38 PM   #5
TJ
TJ's Avatar
Use a dab of some E-6000. It will stay in place with no worries. It's an epoxy glue you can get at hardware or auto parts stores.
Old 11-06-2020, 09:37 PM   #6
jimalabam
jimalabam's Avatar
the '50 ornament was much improved...
jimalabam is offline   Reply With Quote
Old 11-07-2020, 12:29 AM   #7
50fordcoupeman
Smile Re: 49 hood ornament
I know they are not exactly the same but they are very similar of how they fit into the chrome hood ornament. I have used silicone on both 49s and 50s.
