Old 06-16-2020, 06:46 PM   #1
Chris_AAFord
Default Reds Headers. Washers?
Hi Fordbarn,
I just got a set of Reds Headers for my 39 Sedan and it came with a bolt kit but no washers.
What are your thoughts? Should I pick up a set of lock washers? Locktite? Just use the bolts as is?
Thanks for your input.
Chris
Chris_AAFord is offline   Reply With Quote
Old 06-16-2020, 10:42 PM   #2
19Fordy
19Fordy's Avatar
Default Re: Reds Headers. Washers?
I use flat washers and antiseize compound. I am afraid the lockwashers will
crack and break due to expansion and contraction and loose their effectiveness.
No Loctite.
19Fordy is online now   Reply With Quote
Old 06-17-2020, 09:35 AM   #3
Zax40
Zax40's Avatar
No Loctite.
I did the same. Use a good grade washer and hi temp anti-seize. Check torque every 6 months or so.
Zax40 is offline   Reply With Quote
Old 06-17-2020, 03:09 PM   #4
vilanar
Nord-Lock washers and anti seize. With those washers they will stay tight.
vilanar is offline   Reply With Quote
