Old 01-24-2015, 11:06 AM   #1
Gary WA
Gary WA's Avatar
Default Valve Caps (tires)
Did each tire have a valve cap for removing valve or one per vehicle from factory? JS dosen't really say but that spare had one and the others?
www.whidbeymodelaclub.com
Old 01-24-2015, 11:58 AM   #2
Fred
Default Re: Valve Caps (tires)
They all had one....
Fred is offline   Reply With Quote
Old 01-25-2015, 06:19 PM   #3
peters180a/170b
peters180a/170b's Avatar
EXCEPT ACME valve stems... ALL stems on the ground had a full cap and ONLY the spare had the valve remover cap... 1 out of the 5
peters180a/170b is offline   Reply With Quote
Old 01-26-2015, 10:18 AM   #4
Steve Wastler
Steve Wastler's Avatar
You sure about that Pete?
From The Revised 2011 JS&RG
In the general description - "Valve Cap - All valve caps were unpolished nickel plated and had a core remover tip."
In the ACME description - "Valve cap - The core remover valve cap was 5/8" tall with a 23/64" diameter base. the upper portion had a slightly larger diameter with an x knurling pattern."
Listed on the component chart, All ACME stems used the 301 ACME cap, which is a core tip cap.
If there is something I'm missing, could you point me in that direction.
Steve Wastler is offline   Reply With Quote
