Old 03-18-2018, 08:42 PM   #1
slick40
Default Broken door latch on 40 Tudor
I have window frame screws out upholstery loose, window crank, door latch handle off, arm rest is still hooked on, can't budge it how does window frame come loose? Thanks for some help. Gene
slick40 is offline   Reply With Quote
Old 03-18-2018, 09:24 PM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: Broken door latch on 40 Tudor
If you mean the garnish molding, once the screws are removed, it should come off with a good jerk.
4dFord/SC is offline   Reply With Quote
Old 03-19-2018, 08:04 AM   #3
slick40
The top part came loose but the lower half is tight vent window and all. Gene
Old 03-19-2018, 08:27 AM   #4
Darrell S
Darrell S's Avatar
Is the rubber molding around the vent window stuck to the door?
Darrell S is offline   Reply With Quote
Old 03-19-2018, 08:28 AM   #5
TJ
TJ's Avatar
Pull the top outward past the door frame and lift it upward. It should come right out. Then make sure all the door panel clips are loose and then pull up on the panel so it clears the slot for the arm rest.
