Old 04-05-2017, 09:22 AM   #1
alhansen
Default Overheasting
My '31 has had an overheating problem as long as I've owned it....before and after I converted to 12v and electronic ignition. Its got a C head as well. Had the radiator cleaned/ rodded out. I wondered if timing could be a problem so I installed a timing indicator and marked the flywheel pulley so I could check with a timing light. At low Idle ignition is about 18 degrees ATDC. With higher RPM it goes to about 8 BTDC. Probably not looking in the right places but I cant find anywhere the proper numbers. Appreciate any guidance!
alhansen is offline   Reply With Quote
Old 04-05-2017, 09:40 AM   #2
Art Newland
Art Newland's Avatar
Default Re: Overheasting
That seems like retarded timing which can certainly cause overheating. Better contact your ignition manufacturer and see what they think. Does it seem low on power?
Art Newland is offline   Reply With Quote
Old 04-05-2017, 09:48 AM   #3
alhansen
Thanks Art...I would have thought too advanced would cause overheating more likely but perhaps either will do it. Car starts and seems to run great and also have as much power as I would expect from a 40 HP engine. Will do as you suggest and call ignition manufacturer.
Old 04-05-2017, 09:55 AM   #4
Art Newland
Normal A timing is set at TDC with lever set at full retarded position.
Old 04-05-2017, 10:28 AM   #5
Hicktick
Hicktick's Avatar
Sounds like time to buy you a new radiator or have it recored .
Not many radiator shops actually Rod out a radiator properly . If you have always had an overheating problem , , buy you a new radiator .
Sometimes I want to say ,,You should have bought a Shay.
Hicktick is offline   Reply With Quote
Old 04-05-2017, 11:16 AM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
I think your timing is too late. It should be 0 degrees with the handle full up for starting.
With the C head it should be about 15* for idle, and in the 20's for driving.
With my stock head I set it 20* for idle and 30* max for driving.
Old 04-05-2017, 11:47 AM   #7
TerryH
TerryH's Avatar
You didn't mention your carburetor; too lean will also make it run hot.
TerryH is offline   Reply With Quote
Old 04-05-2017, 12:09 PM   #8
Bruce Adams
Bruce Adams's Avatar
Pick up a $30 infra red thermometer at Harbor Freight and SHOOT the radiator when warmed up to see if there are any COLD SPOTS which would indicate clogs in the radiator. There should be a consistent drop in temp from top to bottom. If clogged you might have to purchase a new radiator since you have already went through the rodding fix.
Bruce Adams is offline   Reply With Quote
Old 04-05-2017, 12:26 PM   #9
Mitch//pa
From what u posted your timing is way off. Fix this first
Old 04-05-2017, 01:06 PM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The most COMMON cause of overheating is rust flakes stuck in the upper end of the radiator tubes. BACK FLUSH IT.
Bill Cool
"THE ASSISTANT GURU OF STUFF"
Old 04-05-2017, 07:03 PM   #11
Big hammer
Just a thought model B timing cover would cause the timing to be off? I've heard about it but can't remember which way was what. With timing off that far can't believe it will start let alone run.
Old 04-05-2017, 09:26 PM   #12
SteveB31
SteveB31's Avatar
It has been my observation that 90% of all overheating problems in Model A's is a radiator not dissipating heat efficiently.
SteveB31 is offline   Reply With Quote
Old 04-05-2017, 11:06 PM   #13
denniskliesen
denniskliesen's Avatar
Tom, why is that? Compression? I noticed mine doesn't run any better pulled 3/4 of the way down than 1/3 down. 6:1 ratio 100lbs. compression in all 4 cylinders.
denniskliesen is offline   Reply With Quote
Old 04-06-2017, 12:06 AM   #14
Tom Wesenberg
Higher compression burns faster, so it needs less spark advance. My engine has 50 PSI on all 4.
Old 04-06-2017, 06:32 AM   #15
colin1928
colin1928's Avatar
Ford spec for a C model head idle 18 deg BTDC - 34 BTDC deg total
colin1928 is offline   Reply With Quote
Old 04-06-2017, 07:12 AM   #16
George Miller
George Miller's Avatar
Plus 1
George Miller is offline   Reply With Quote
Old 04-06-2017, 07:22 AM   #17
rocket1
I have a Stude. that ran hot for years even after the radiator was so called cleaned,tried everything else and finally replaced the radiator in desperation,that solved the problem.
rocket1 is offline   Reply With Quote
