Old 10-07-2015, 06:54 AM   #1
BILL WZOREK
BILL WZOREK's Avatar
Default Pine pitch on windshield
Any good way to remove it ?
BILL WZOREK is offline   Reply With Quote
Old 10-07-2015, 07:17 AM   #2
Joe777
Joe777's Avatar
Default Re: Pine pitch on windshield
I have used a razor blade with good results. Let the spot dry and carefully scrape it off with the blade. I haven't found any solvent or cleaner that will dissolve the pine pitch. Hope this helps.
Joe777 is offline   Reply With Quote
Old 10-07-2015, 07:36 AM   #3
alan
"goof off" soaked in a rag works good, still can be hard to get off
alan is offline   Reply With Quote
Old 10-07-2015, 07:37 AM   #4
john worden
john worden's Avatar
razor blade than wax and grease remover?
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 10-07-2015, 07:44 AM   #5
G.M.
Try denatured alcohol. G.M.
www.fordcollector.com
Old 10-07-2015, 07:45 AM   #6
Barry-ct
Barry-ct's Avatar
Ford makes an excellent Tar and Bug remover. Doesn't hurt paint and cuts thru most things like road tar, pine pitch, etc... Most dealers stock it or can get it from their Motorcraft wholesaler.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 10-07-2015, 07:45 AM   #7
Bruce in southern OH
Bruce in southern OH's Avatar
Can of Coke, yes it works.
Bruce in southern OH is offline   Reply With Quote
Old 10-07-2015, 08:06 AM   #8
corvette8n
corvette8n's Avatar
Razor blade then clean with "Goo Gone" our Dollar store carries it.
Old 10-07-2015, 08:50 AM   #9
Karl Wescott
Karl Wescott's Avatar
Acetone works very well. Use caution close to paint.
Karl Wescott is offline   Reply With Quote
Old 10-07-2015, 08:54 AM   #10
skyfright
Gasoline used to work. I don't know about this stuff we have now.
Ron
skyfright is offline   Reply With Quote
Old 10-07-2015, 08:55 AM   #11
GreenMonster48
GreenMonster48's Avatar
Rubbing alcohol will loosen it up on glass.
GreenMonster48 is offline   Reply With Quote
Old 10-07-2015, 08:55 AM   #12
TJ
TJ's Avatar
Regular mineral spirits thinner or Naptha. Neither will hurt the paint.
Old 10-07-2015, 10:23 AM   #13
Marvin/TN
Send a message via AIM to Marvin/TN
Use a single edge razor blade, mark it some way so the same side is always up,(it will scratch the glass if you turn it over), use some windex or similar product or a soapy water solution, keep the razor at a very low angle, and scrape away. This process will
also work with paint over spray. The secrete is to never turn the blade over.
Marvin/TN is offline   Reply With Quote
Old 10-07-2015, 11:27 AM   #14
Scott H in Wheaton
Scott H in Wheaton's Avatar
Marvin, thanks for the tip on the razor blade. I've been using them for years and years on windshields and can't see that I've ever scratched one, but I will watch out more closely in the future. I always used both sides, and used a very low angle of approach.
Scott H in Wheaton is offline   Reply With Quote
Old 10-07-2015, 11:57 AM   #15
Kahuna
Kahuna's Avatar
TJ wins. best stuff to use
Kahuna is offline   Reply With Quote
Old 10-07-2015, 08:06 PM   #16
34billct
34billct's Avatar
Wile visiting Yellow Stone NP on my cross country tour in the 34 we stayed at motel with a big pine tree witch i parked under. In the morning the 34 had blobs of pine tar all over, soap will not work. But Gin works great!
34billct is offline   Reply With Quote
Old 10-07-2015, 08:11 PM   #17
paul2748
paul2748's Avatar
Try lacquer thinner. Be careful.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 10-07-2015, 08:15 PM   #18
jim galli
jim galli's Avatar
WD-40 takes the pitch off. Soap and water takes the WD-40 off.
He is no fool who gives what he cannot keep, to gain what he cannot lose... Jim Elliott, 1949
http://tonopahpictures.0catch.com
jim galli is offline   Reply With Quote
Old 10-07-2015, 08:51 PM   #19
DD931
DD931's Avatar
Actually, regular turpentine is the same stuff as pine pitch and should dissolve it easily!! And I don't think it will hurt paint!
DD931 is offline   Reply With Quote
Old 10-07-2015, 09:51 PM   #20
Drbrown
Drbrown's Avatar
We get dripping pitch from the pine trees here in the NY State. Paint thinner or turpentine on a soft cloth works great. Paint thinner is made to contain more oil residue than turp, but both wash off with soap and water. Just rub gently and patiently. Will not hurt paint. Also a good rubber cleaner - follow with a coat of glycerin to restore rubber's resiliency and water repealency.
Some cars manufactured in the early 1900's often recommended these products, combined with bee's wax, for polishing cars.
Drbrown is offline   Reply With Quote
