Old 08-10-2015, 03:01 PM   #1
Ianrhall
Default Lever arm shock bushes
Been under my jailbar truck tonight looking to reduce rattles and bangs!!
It has original type lever arm shocks, they are working well and have plenty of resistance in them. The rubber bushes on the arms that connect shocks to the axle need replacement and the ball joint rods st the front are shot. Are these parts available?
Thanks
Ian
Ianrhall is offline   Reply With Quote
Old 08-10-2015, 11:24 PM   #2
fordor41
fordor41's Avatar
Default Re: Lever arm shock bushes
Try mac's. Most ford parts houses have different length shock links
fordor41 is offline   Reply With Quote
Old 08-11-2015, 01:16 AM   #3
Ianrhall
I'm seeing ones for cars but not trucks.
Old 08-11-2015, 10:11 AM   #4
35fordtn
35fordtn's Avatar
Ian to my knowledge nobody has reproduced the 42-47 truck shock links. The rubber ball bushings are not designed to be replaceable in the link itself. You will likely have to find them in NOS.
35fordtn is offline   Reply With Quote
Old 08-11-2015, 10:13 AM   #5
Ianrhall
Oh, is there supposed to be a rubber bushing in there? No wonder it rattles about then
Ian
Old 08-11-2015, 10:30 AM   #6
BILL WZOREK
BILL WZOREK's Avatar
Before " ALS " I was working on getting these reproduced >>
Any interest ?
I would be at ground zero & restarting with my old note's.
BILL WZOREK is offline   Reply With Quote
Old 08-11-2015, 11:05 AM   #7
Ianrhall
I think I will be able to find some bushes for the rear, not sure what to do about the fronts tho. Shame as all 4 shocks are in good working order
