Old 10-15-2021, 03:51 PM   #1
kurt v
Default 1940 wiper motor
Is it possible to lube the motor without taking it apart, mine cycles but sticks once in a while ?
thanks kurt
kurt v is offline   Reply With Quote
Old 10-15-2021, 05:20 PM   #2
kurt v
Default Re: 1940 wiper motor
I got it working, couple drops of 3&1 oil in tube now it works good.
Old 10-16-2021, 07:03 AM   #3
TJ
TJ's Avatar
A little Marvel Mystery Oil will also do the trick.
Old 10-16-2021, 10:27 AM   #4
Terry,OH
Terry,OH's Avatar
Sticks? If at the extremes the problem is most likely in the small metal cover. There is a switching device that moves to switch the vacuum so the motor can reverse. The switching device can stick or hang up.
Old 10-17-2021, 03:53 AM   #5
deuce lover
deuce lover's Avatar
Here is a pic of what Terry mentioned.
