09-17-2021, 02:39 PM | #1 |
1938 windshield seal
Could someone help me about a 38 windshield frame seal. I have a B.Drake one and it seems like a real struggle to seat it. Any help would be appreciated.
09-17-2021, 07:04 PM | #2 |
Re: 1938 windshield seal
A little soap goes a long way. But, if there is a lot of rust or old rubber in there you will probably struggle a lot. Make sure it is clean and painted down inside.
09-17-2021, 09:00 PM | #3 |
As stated above, the channel must be clean of all old seal, rust, and scale for the new seal to properly seat. This might require ingenuity in finding /making tools to clean properly. Look at the design of the lip to see where the hard-to-access ledges are.
09-18-2021, 02:11 PM | #4 |
Thanks for the heads up about the channel. soap and clean of rust and old seals.
09-18-2021, 05:09 PM | #5 | |
Being certain the channel is 100% CLEAN, as others have mentioned is paramount to seating the new seal. Get the four "corners" seated before doing any of the horizontal or vertical runs.
