10-16-2023, 05:06 PM | #1 |
Lightened flywheel
Does anyone know where I can buy a lightened flywheel for my '31 coupe?
10-16-2023, 05:25 PM | #2 |
Re: Lightened flywheel
10-16-2023, 06:12 PM | #3 |
How does a lightened flywheel affect MPG? I understand the ability to spin rpms quicker, but I would think the heavier flywheel would carry rpms longer saving gas on a touring engine. As I prepare to have new bearings installed in my engine, this is also a consideration.
10-16-2023, 06:40 PM | #4 |
Is your crankshaft counter balanced? If not I don’t know if you would want to take weight off the flywheel.
10-16-2023, 06:41 PM | #5 |
You might want to look at this discussion from a few years ago. Raises some very good questions.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
10-16-2023, 08:08 PM | #6 | |
10-16-2023, 08:34 PM | #7 | |
If you do that, you should have the flywheel/clutch and disc balanced, each separately and then the flywheel and clutch cover as an assembly. |
10-17-2023, 06:30 AM | #8 |
Be aware, Burtz's lightened flywheel is drilled for the v8 clutch.
Frank |
10-17-2023, 06:41 AM | #9 | |
http://www.durableperformance.net/about.html |
10-17-2023, 10:10 AM | #10 |
Flywheel weight (rotational inertia) is more complicated than initially perceived. The crankshaft has rotational vibration at all speeds, more at some speeds called critical rpm. The Ford engineers were either pretty lucky or pretty smart in that the flywheel inertia was just enough to cancel out the rotational vibration of the crankshaft so that it was not felt by the driver.
There is a spot along the length of the crankshaft where there is no rotational vibration, called a node point. With the original flywheel that point is the flywheel. With a lightened flywheel the node point moves forward so that now the flywheel is experiencing rotational vibration. The driver can feel this in the steering wheel when driving a car with a lightened flywheel. More so at lower rpm. The addition of counterbalancing weights complicates this and changes where the node point is and how much rotation vibration is felt in the lightened flywheel. The rotational vibration causes stress in the crankshaft and will lead to breakage under certain conditions. The addition of a vibration (rotational) dampener at the front of the crankshaft will reduce the rotational stress in the crankshaft.
10-17-2023, 03:28 PM | #11 | |
6500 rpm twice a lap. 168 hp at 5800 rpm. |
10-17-2023, 03:59 PM | #12 |
I can't really tell from the picture, is that flat or overhead?
10-17-2023, 04:03 PM | #13 |
10-17-2023, 05:50 PM | #14 |
Pete, how is the vibration at 1,200 rpm? Your vibration dampener is doing its job.
10-17-2023, 06:02 PM | #15 |
10-17-2023, 07:39 PM | #16 |
I picked up a trick B engine a couple weeks ago. Aluminum flywheel and homemade dampner (not sure if that's right since there is no rubber in it). It's got a cross drilled "C" (yeah I know - no such thing) crank.
I'm always reminded of lessons from a friend while building race cars. Make it light - every pound you take out is a pound you don't have to accelerate or stop. |
10-18-2023, 08:14 AM | #17 |
29, That is an interesting engine. The "dampener" looks like a flywheel more than a dampener. Putting flywheels at each end of the crankshaft will change things and I am not sure how things will change. Usually the most extreme twisting is at the front.
Dampeners have two ways of dampening the torsional vibration. One is through the rubber connection to a heavy disk and the other is through some sort of friction connection. The rubber connection actually wears out after a while because of the constant flexing. Dampeners are designed for each engine using computer simulation and testing. It is not something that an average gear head can do.
10-18-2023, 08:45 AM | #18 | |
Y'all really want to discuss the effectiveness of a balancer on a Model-A/B engine, explain how this one works?? |
10-18-2023, 10:13 AM | #19 |
Looks like something you might see on a hit-and-miss engine...
10-18-2023, 11:50 AM | #20 |
It doesn’t
J
As Carroll Smith wrote; All Failures are Human in Origin. |
