Old 03-12-2023, 01:26 PM   #1
CA Victoria
CA Victoria's Avatar
Default 1933-1934 4 Cylinder Parts
There must be restorers outside of the circle of friends here on the Ford Barn with an interest in the later 4 cylinder engines.
I need a crank shaft pulley. If you can recommend another restorer with a parts cache please drop me a note.
Thanks!
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 03-12-2023, 02:35 PM   #2
mcgarrett
Default Re: 1933-1934 4 Cylinder Parts
Would this one work for you?
https://www.fordbarn.com/forum/showthread.php?t=323183
mcgarrett is offline   Reply With Quote
Old 03-12-2023, 03:04 PM   #3
CA Victoria
Many and me included did not realize that the 33-34 pulley is shorter to accommodate the short water pump used.
The pulley shown in your pictures is identified as a 28-34 pulley but is to long to use with the shorter 33-34 water pump.
I am working on this for a friend, his engine is going into a 33 pickup that is disassembled.
Tim
Downtown, Ca
Old 03-12-2023, 03:27 PM   #4
Bob C
Here's a NOS one. $$$$$
http://www.allfordparts.com/shop/pro...&model=46-6312
Old 03-12-2023, 03:42 PM   #5
CA Victoria
$375...........That is ridiculous. Albeit he has a large inventory......he has been notoriously high priced......it appeals to those who do not know were to look or do not have time........
I have found that NOS and hard to find often equates into unrealistic prices.
I have also found many NOS and hard to find parts by asking around.
Tim
Downtown, Ca
Old 03-12-2023, 07:38 PM   #6
J Franklin
J Franklin's Avatar
Exactly! If you don't have the time to thoroughly search, then the price is correct, plus the shop has overhead to consider.
Old 03-12-2023, 08:18 PM   #7
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
Tim, Can you turn down a Model A pulley to shorten it to the correct length ?
dansluck is offline   Reply With Quote
Old 03-12-2023, 09:32 PM   #8
CA Victoria
No, because the pos. offset is greater on the A-B style. I located a photo of the 46-6312 pulley.
File Type: jpg 77D3B569-0DF0-42CE-92AC-0B6CEBDF429D.jpg (49.0 KB, 45 views)
Tim
Downtown, Ca
Old 03-13-2023, 06:45 AM   #9
Dave Slater
Dave Slater's Avatar
I manufacture the pulley for the 33/34 4 cylinder engine out of one piece billeted steel and have them on two of my cars. If you send me an email I can send a photo of the finished product. Currently out of stock however the next batch of pulleys should be finished in two weeks . [email protected]
Dave Slater is offline   Reply With Quote
Old 03-13-2023, 11:20 AM   #10
Bob C
You might PM barnfind08 on the Early V8 forum on this site, he has buildings full of NOS parts. Email [email protected]
