10-02-2021, 04:32 PM | #1 |
Points don't fit
Bought a set of points from one the A parts dealers. The points don't fit so well. There is part of the front hanging off the point face. This is my first time of installing points in a model A. Is this common? Who has the best quality, original style points?
Thanks |
10-02-2021, 04:47 PM | #2 |
Re: Points don't fit
I like Bratton's. I also use their machined stationary point block. It is made to align the pointshttps://www.brattons.com/MACHINED-DI...uctinfo/17351/
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 10-02-2021 at 04:54 PM. |
10-02-2021, 05:00 PM | #3 |
A photo would help.
10-02-2021, 05:22 PM | #4 |
Yep, seems to be a problem sometimes.
I've had to do some drilling/filing to get them where they need to be. |
10-02-2021, 07:47 PM | #5 |
Yeah that is because they don't make the points correctly nowadays and apparently can't be bothered to correct it. The workaround is per above, the vendors sell a specially machined point block that better (but not perfectly) aligns the points. Welcome to the world of reproduction parts. This is an example of what makes me nuts about some reproduction parts-like, why couldn't they just make it correctly?
10-02-2021, 10:20 PM | #6 |
Dave / Lincoln Nebraska |
10-03-2021, 11:01 AM | #7 |
The lower plate that was in the distributor of my A had a fixed point block and the new replacement points didn't line up. I had to source a new lower plate and point block and then file the point block mounting holes to get the points to line up.
10-03-2021, 01:06 PM | #8 |
I like to buy nos or nors points because they usually fit. Use the good points until they are worn completely done and you will be surprised how many years they will give good service. Some people just replace points for no real good reason and then find these other problems!
10-03-2021, 01:24 PM | #9 |
NAPA has good points and condensers
10-03-2021, 02:01 PM | #10 |
Just look at Katy's photo. That's not even close to a good part.
10-03-2021, 02:43 PM | #11 |
I can't even imagine where Katy buys parts...
All parts from Bratton's. All repro and fits fine.
Ruth "Sometimes you really DO need to read the whole thread" Last edited by Ruth; 10-03-2021 at 02:51 PM. |
10-04-2021, 09:36 AM | #12 | |
10-04-2021, 10:22 AM | #13 |
Well as you can see from my picture, with Bratton's stationary block cures the problem with no modification to the upper plate.
Ruth "Sometimes you really DO need to read the whole thread" |
10-04-2021, 12:45 PM | #14 | |
Ken
Style beats speed any day, and with a lot fewer tickets. |
10-04-2021, 01:15 PM | #15 |
10-04-2021, 01:24 PM | #16 |
See that...you learn something new every day.
Thanks, Ken
10-04-2021, 03:48 PM | #17 |
Notice how the screw on Katy's plate is outboard compared to the Bratton's, locating the stationary point inward causing the miss alignment. it doesn't appear to me that bratton's points were designed to work on that plate.
10-04-2021, 04:25 PM | #18 |
Did an early plate distributor get different points?
10-04-2021, 07:02 PM | #19 |
Not that I can tell.
"The more things change, the more they stay the same." |
