06-16-2021, 11:53 PM | #1 |
1935 Ford headlight mount
I'm repainting my '35 ford sedan. When I pulled the headlight buckets there was 6 large flat washers and a lock washer on the mounting bolt. Is this correct ? I thought that it should have a heavy spring. If it uses a spring, where can i get one. Thanks for the help.
06-17-2021, 12:18 AM | #2 |
Re: 1935 Ford headlight mount
That hollow bolt goes thru the stand,fender and brace.Flat washer .lock washer and nut.No spring.
06-17-2021, 04:08 PM | #3 |
