Old 11-26-2020, 06:28 PM   #1
30-9
Default 39 deluxe coupe
Delete- I found the part at Carpenter- 91A-7011115-PR —— for the next Barner��
Hi Gents
Need a little assistance again. Going from memory of friends car. I want to replace the wood that the accelerator peddle screws into and goes all the way across to inner side. I did a search on Carpenter and Joe’s antiques.
What is that part called?
What vendor may have?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 11-26-2020, 07:37 PM   #2
swoopNZ
MEMBER EMERITUS
Default Re: 39 deluxe coupe
Macs sells them also - or used to.
PN 32-20170-1
$47.95/pr.
Don't forget the seals as well.
swoopNZ is offline   Reply With Quote
Old 11-26-2020, 08:00 PM   #3
30-9
Thanks didn’t know about the seal. Carpenter is out of stock and I vowed never do business again with Mac’s Auto.
Is rubber under wood or on top. Is it possible to replace wood and not rubber.
Thanks - 30-9
1939, 1940
Old 11-26-2020, 11:40 PM   #4
Barn Junk
Barn Junk's Avatar
Rubber fits on edges to make a better water tight seal.
Barn Junk is offline   Reply With Quote
