Old 04-04-2020, 11:32 AM   #1
40larry
Default Wanted: Ford transmission expert
I have two transmission questions regarding parts used in these transmissions.
1. Is there a difference between the 022a-7113 and 21c-7113 cluster gears? Why are there different part numbers if they are interchangeable?
2. Is there any difference between the 01a-7100 and 21c-7100 low rev slider gears? They appear identical but??
Thanks for your help........40larry
40larry is offline   Reply With Quote
Old 04-04-2020, 11:42 AM   #2
Krylon32
Default Re: Wanted: Ford transmission expert
Contact Mac VanPelt.
Krylon32 is offline   Reply With Quote
Old 04-04-2020, 12:57 PM   #3
hardtimes
hardtimes's Avatar
Hey larry,
I have couple of transmission parts/rebuild books by MAC VANPELT.
You will find everything in the books and more to answer/direct you when messing/rebuilding 3 speed top loader Ford transmissions.
I'm in Canoga Park, you in Northridge. Too bad about this viirus thing, else I could help you up close with you trans problems.
Old 04-04-2020, 01:03 PM   #4
svm99
Larry, I've looked at both the 01C-7100 ans 21C-7100 low gears and see no difference except the 21C sometimes has a small groove in the outer diameter of the flange. I have not compared both of the cluster gears.
svm99 is offline   Reply With Quote
Old 04-04-2020, 01:46 PM   #5
Barn Junk
Barn Junk's Avatar
I believe the only functional difference is in the thrust bushing design used between the cluster gear and the rear of the case.
Barn Junk is offline   Reply With Quote
Old 04-04-2020, 02:30 PM   #6
Mac VP
Mac VP's Avatar
The 21C items were some sort of experimental variation on those gears. The print specs referred to a different heat treatment (and perhaps a little different alloy - I can’t remember) than the regular Ford specs. They stopped listing those for sale a few years after the war. Regardless of a possible difference in the rear thrust washers, you can consider them interchangeable.
VANPELT SALES LLC
Cincinnati, Ohio
Office: 513-724-9486
www.vanpeltsales.com
www.classictransmission.com
Mac VP is offline   Reply With Quote
Old 04-04-2020, 06:19 PM   #7
40larry
If all this is true why would they use the 21C part numbers which are for a 1942 Commercial vehicle? Also the Green Bible lists them with different matching gears and related parts. Thanks for your reply.
40larry
