Old 05-21-2019, 06:46 PM   #1
philipswanson
Default Tie Rod End Torque??
How much torque do you recommend for tie rod ends and the drag link ends when replacing with new parts on a 40?
philipswanson is offline   Reply With Quote
Old 05-21-2019, 08:50 PM   #2
drolston
drolston's Avatar
Default Re: Tie Rod End Torque??
A good hard pull on a 3/8" drive ratchet handle should do the trick. It is not an area where torque specification is critical.
Old 05-21-2019, 09:21 PM   #3
Gary troxel
AND your putting in a cotter pin.
Gary troxel is offline   Reply With Quote
Old 05-21-2019, 09:29 PM   #4
19Fordy
19Fordy's Avatar
I agree.
Old 05-22-2019, 09:46 AM   #5
philipswanson
I am surprised there is no spec for torque on a major steering component such as a tie rod end.. If it was an aircraft, you bet there would be.
Old 05-22-2019, 10:00 AM   #6
deuce_roadster
deuce_roadster's Avatar
You can look up the torque for that diameter and thread in any chart.
Old 05-22-2019, 10:17 AM   #7
philipswanson
I called the Moog tech line and they said 60-65 ft. lbs. to insure the tapered pin draws in fully, then tighten to next notch for cotter key alignment. Thanks to all.
Phil Swanson
Old 05-22-2019, 10:24 AM   #8
drolston
drolston's Avatar
These cars were maintained for decades by shade tree mechanics, 99% of whom did not own a torque wrench. You wring off a few bolts and strip a few threads, and you learn how hard to pull on that wrench. So, don't over think torque specifications. The only place it is critically important is cylinder heads. And the shade tree torque spec for those is as hard as you can pull a 1/2" drive long bar with one hand.
Old 05-22-2019, 11:45 AM   #9
philipswanson
We can all do better than that regardless of what was done before.
Old 05-22-2019, 01:05 PM   #10
51 MERC-CT
51 MERC-CT's Avatar
There is a torque spec in the '49-'51 Linc/Merc manual and is consistent with what MOOG said.
