Old 03-18-2021, 09:24 AM   #1
wbs
Default 1930 roadster hood latches
hello- i understand that hood shelves were discontinued in 1930. so, were the latches bolted directly to front fender and when ordering latches do i ask for 30 latches or will any year do? thank u
wbs is offline   Reply With Quote
Old 03-18-2021, 10:11 AM   #2
31Tudor
31Tudor's Avatar
Default Re: 1930 roadster hood latches
The front hood latch bolts through the hood latch, fender and frame rail. The rear latch bolts through the hood latch, the fender and the pad on the frame with slotted holes. You would order hood latches for 30-31. They are the same with a two screw base.
31Tudor is offline   Reply With Quote
Old 03-18-2021, 01:56 PM   #3
wbs
thank you
Old 03-18-2021, 02:07 PM   #4
Mikeinnj
Mikeinnj's Avatar
You did not state what year car you are working on. The 28-29 latches are different from the 30-31 When ordering you must specify what year your car is.
Mikeinnj is offline   Reply With Quote
Old 03-19-2021, 10:54 AM   #5
katy
katy's Avatar
The title of the thread says it all: "1930 roadster hood latches"
Old 03-22-2021, 12:28 PM   #6
wbs
thanks again to all who replied--my car came in pieces and neither could i find any posts or pix
