07-24-2014, 05:20 PM | #1 |
Cracked Fan
Took the wife to lunch today and upon return I checked the engine compartment to see a new 1/2 inch crack in the two blade original fan an inch from the hub. Dang it. Although, thankful I noticed it since there is a new radiator inches from it. Time for an upgrade. Thoughts?
Simplicity is the ultimate sophistication. L.D. I have 40 horses in the garage. Only feed them when I want to take them out. 31 Model A Tudor 55B Nick Last edited by nickair; 07-24-2014 at 11:37 PM. |
07-24-2014, 05:35 PM | #2 |
Re: Cracked Fan
Question: is it a new fan, relatively new fan, or an old fan?
I have a steel four blader on my '30, and I examine it occasionally for cracks. I have been told to replace it as it will eventually work harden from vibration and crack. Yet, what to replace it with? I have heard of folks having problems with repro fans.... Thanks |
07-24-2014, 05:48 PM | #3 |
Re: Cracked Fan
"a new 1/2 inch crack" Are there others?? This is an aluminum fan??
Paul in CT |
07-24-2014, 06:33 PM | #4 |
Re: Cracked Fan
Yes, the fan is an original steel 2 blade. This crack is the only one. Photo attached
Simplicity is the ultimate sophistication. L.D. I have 40 horses in the garage. Only feed them when I want to take them out. 31 Model A Tudor 55B Nick Last edited by nickair; 07-24-2014 at 11:36 PM. |
07-24-2014, 06:43 PM | #5 |
Re: Cracked Fan
Are you sure that is aluminum, looks like an original to me. Almost
looks like one one I have. Bob |
07-24-2014, 07:23 PM | #6 |
Re: Cracked Fan
07-24-2014, 07:42 PM | #7 |
Re: Cracked Fan
Try a magnet on it.
07-24-2014, 07:43 PM | #8 |
Re: Cracked Fan
nickair,
Take a magnet and see if it sticks to the fan or not. I am with the others as it does not look like a aluminum fan, at least not the current ones out now. BUT...Who knows what old Henry was experimenting with during the Model A era! Pluck |
07-24-2014, 07:49 PM | #9 |
Re: Cracked Fan
Holy cow, where's the duct tape when you need it?
Yep, it's steel. I just put a magnet to the picture of it, and it stuck. |
07-24-2014, 09:23 PM | #10 |
Re: Cracked Fan
Dog here,
Well, personally, my Buddy, Ol' Bill & I don't trust anything made out uf BEER CANS, Vermin sports a 6 blade, BLACK plastic fan NEVER seen one BREAK! Buster T.
07-24-2014, 10:51 PM | #11 |
Re: Cracked Fan
Quick, get the JB weld !!! just joking. Actually my thought also is that it looks like an original. The sides of the pulley look too thin to be an aluminum repro. No harm meant and I'm not tring to make you out to be a lie. Do the magnet test, but by all means replace the fan before it does greivious harm !!!
07-24-2014, 11:47 PM | #12 |
Re: Cracked Fan
Plastic fans break too, i have replaced several, along with the radiator sliced by the blade and dents in the hood
07-24-2014, 11:50 PM | #13 |
Re: Cracked Fan
Just buy a new repro aluminum fan. The quality is good. No worries.
07-24-2014, 11:54 PM | #14 |
Re: Cracked Fan
I just did the highly technical magnet test on the fan. It is an original steel two blade. Thread post is now edited to reflect correct fan material. I assumed it was a replacement rather than an 83 year old original. We all know what assuming gets us. Oops. Thanks guys for pointing it out from my photo.
Now what about replacement options? Thoughts...
Simplicity is the ultimate sophistication. L.D. I have 40 horses in the garage. Only feed them when I want to take them out. 31 Model A Tudor 55B Nick |
07-25-2014, 12:18 AM | #15 | |
Re: Cracked Fan
07-25-2014, 12:26 AM | #16 |
Re: Cracked Fan
I've run one of those 6 blade plastic fans for many thousands of miles with no sign of trouble - not that the aluminium fan on my other car has been found wanting. As I see it, if you want things to look close to original, go for the Al fan, otherwise consider the plastic one.
Good pick up before it separated!! Well spotted. |
07-25-2014, 04:54 AM | #17 |
Re: Cracked Fan
You were very lucky because that's a major crack and soon would have been in two pieces.
You can also see rust pits where the fan meets the hub. I'd buy an aluminum fan. |
07-25-2014, 05:51 AM | #18 |
Re: Cracked Fan
Geee!!! Lucky it did not fly apart!!!
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-25-2014, 09:02 AM | #19 |
Re: Cracked Fan
Just some advice: Don't start the motor until you replace the fan.
Retired civil engineer. Winters in Phoenix, summers in Ipswich, Mass. and North Dakota. '29 closed cab pickup- Excellent AZ truck. '29 roadster- Owned for 21 years but now sold. '28 CC pickup- My first car in Andover, MA back in '62- '63. |
07-25-2014, 09:28 AM | #20 |
Re: Cracked Fan
