04-26-2021, 03:05 PM | #1 |
Any recomendations
ANY one have a recommendation on an Ammeter gauge repair??
04-26-2021, 03:43 PM | #2 |
Re: Any recomendations
Maybe you could try a speedometer guy, see what he says
https://www.fordbarn.com/forum/showthread.php?t=269960 |
04-26-2021, 04:31 PM | #3 |
Williamson's?
https://williamsons.com/
04-27-2021, 09:18 PM | #4 |
I am sure you can find a good used one much cheaper than having yours rebuilt.
04-28-2021, 02:03 AM | #5 |
There are several 1932 Ford ammeters in the upcoming Gene Hetland ford parts auction. Just exactly what is wrong with your ammeter ? Does it not just work or is it burnt or damaged to look at. I have repaired many gauges but am in Australia. Regards, Kevin.
04-28-2021, 07:29 AM | #6 | |
Thanks BUT mine is in GERMAN and for a German 32, none of those are "floating Around". on "Ebay" OR in the Gene Hetland auction!!! |
04-28-2021, 07:32 AM | #7 | |
As you see above mine is "stuck" at 10 (or 12). The needle giggles and moves as IF it were normally on "0" but its stuck there at 10. I am going to put it on an amp machine and try and run a negative amperage pull to see IF the needle moves like it should BUT even still It will need a repair of some sort!!!! |
04-28-2021, 08:34 AM | #8 |
I have heard good things about John Wolf and Co. Inc. in Willoughby, OH.
https://www.antiqueinstrument.com/ |
04-28-2021, 10:00 AM | #9 |
If you can't fix yours how about getting a US one and install your German face.
04-28-2021, 04:19 PM | #10 |
The old Model A instruments were easy to disassemble if you had the special tool to take the terminals apart but I don't know about the 1932 & later and especially those that may have been made in the country of origin. If there is a clock spring in there, it may be damaged or something slipped in the spindle shaft that the pointer is attached to. Some of the pointers can slip off center.
