11-17-2021, 11:21 AM | #1 |
Drivers door
Drivers door starter coming unlocked while driving down the road. unlocked not open all the way. Is it a simpler adjustment on the door striker or something else ? Body shifting loose body/frame bolts ??
Thank, |
11-17-2021, 11:26 AM | #2 |
Re: Drivers door
Could be wear on striker or plunger on latch unit. Or, tension on spring for plunger.
11-17-2021, 07:41 PM | #3 |
Re: Drivers door
Check what oldblu pointed out, and play with / adjust the striker...can't hurt
Check hinge pins too, does door have a lot of up/down movement when open? (Used to live in North Highlands when I was at McClellan AFB, Lou's Burgers on Watt Ave had the best triple burger in the World, can still almost taste them after 30 years+) Make that 40+ years
Keith Shawnee OK '31 SW 160-B Last edited by burner31; 11-18-2021 at 07:48 PM. Reason: Forgot what year it was |
11-17-2021, 10:38 PM | #4 |
Re: Drivers door
