12-27-2019, 09:46 PM | #1 |
36 ford temperature gauge
Can the factory gauge be repaired if the line to the motor has been cut? My gauge still has the liquid in it.
12-28-2019, 01:19 AM | #2 |
Re: 36 ford temperature gauge
Yes.Contact John Wolf & Co in Willoughby,OH. It was a '34 dualtemp.The entire line has to be replaced and charged. Was a 2 week turn around for me.
12-28-2019, 07:22 AM | #3 |
Thank you! I'm actually like 45 minutes from there shop!
12-28-2019, 08:21 AM | #4 |
My only complaint is they will replace the steel nut(for water pump port) with an aluminum unless you specify to use the original(if you have it).They didn't tell me that.I had even sent a steel nut (2 ft of my line was gone) that I cleaned which they tossed.
12-28-2019, 06:17 PM | #5 |
How much should one expect to pay for one?
01-14-2020, 05:44 PM | #6 |
A man should do what he thinks best! "The Duke" |
