11-26-2021, 07:22 PM | #1 |
Bad Tube
I bought tires and tubes off craigslist about 6 years ago they were all in plastic bags. When I got home, I stuffed the new tubes inside the new tires and aired the tubes a little so they wouldn't wrinkle and crack. Stored indoors the made in USA tubes still cracked zero miles never mounted I only checked one bag. But will replace them all. The tires were half price tubes included .
Dennis in Kelsey ca Last edited by Dennis Pereira; 11-26-2021 at 07:27 PM. |
11-26-2021, 07:58 PM | #2 |
Re: Bad Tube
They didn’t crack, they rotted!
11-26-2021, 08:06 PM | #3 |
Re: Bad Tube
Looks like when I catch one with the tire iron.
11-26-2021, 08:28 PM | #4 |
Re: Bad Tube
That's nasty
11-26-2021, 08:45 PM | #5 |
Re: Bad Tube
Ozone will deteriorate rubber pretty quickly. A source of ozone can be from a refrigerator compressor or electric motor, etc. If you store anything rubber in a confined area (closet) with stuff like that, it will do what is in the photo.
1930 Standard Coupe |
11-26-2021, 08:57 PM | #6 |
Re: Bad Tube
Dennis in Kelsey ca |
11-26-2021, 09:15 PM | #7 |
Re: Bad Tube
#5 is spot on.
Imported rubber (far from pure rubber) just ages quickly. I’ve seen older tubes wrapped but come out deteriorating |
11-27-2021, 10:16 AM | #8 |
Re: Bad Tube
should have bought Chinese ones.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
11-27-2021, 11:04 AM | #9 |
Re: Bad Tube
There were some bad tubes sold a few years ago that weren't much good even when they were new. A good quality tube kept out of the light, especially in a tire can easily last 40+ years.
11-27-2021, 12:29 PM | #10 | |
Re: Bad Tube
These days most (if not all) refrigerator compressors are sealed units.
11-27-2021, 07:47 PM | #11 | |
Re: Bad Tube
As an interesting side note, apparently the ozone generated by electric cars is so high that it has caught the attention of environmentalists. See, our model As are eco friendly after all!
11-27-2021, 09:28 PM | #12 |
Re: Bad Tube
I have the same tubes in my tires, only 19 inch. They have been in there for years and are still good, if I don't pinch them with the tire iron.
Lightening will also generate ozone. You can smell it after a lightening strike. The electrical spark will split the oxygen molecule (O2) into oxygen atoms (O). The oxygen atoms will quickly combine with an oxygen molecule to form ozone (O3).
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 11-28-2021 at 09:38 AM. |
11-29-2021, 12:16 PM | #13 |
Re: Bad Tube
That may be a good thing as there was talk about depletion of the ozone layer of the atmosphere.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 11-29-2021 at 12:17 PM. Reason: Typo |
