Old 11-26-2021, 01:15 AM   #1
JohninKuranda
JohninKuranda's Avatar
Default Fuel shut off valve leak
I have a leaking shut off valve in my 1928 35A Phaeton Canadian built RHD. I have taken it apart and have noticed some minor scoring in the lower part of the brass tapered body. Is there away that this can easily and safely be made serviceable and leak proof again? Or should I just purchase a replacement fuel shut off valve?
JohninKuranda is offline   Reply With Quote
Old 11-26-2021, 04:25 AM   #2
mercman from oz
mercman from oz's Avatar
Default Re: Fuel shut off valve leak
John in Kuranda Australia needs some advice with his leaking Model A Ford Gas Shut off Valve. Can anyone help him out?
mercman from oz is online now   Reply With Quote
Old 11-26-2021, 07:04 AM   #3
aermotor
Lap with 20 Mule Team Borax, Arm & Hammer washing soda or maybe Comet or other kitchen cleanser with an abrasive.
John
aermotor is offline   Reply With Quote
Old 11-26-2021, 07:50 AM   #4
rotorwrench
rotorwrench's Avatar
Timesaver fine lapping compound may be more appropriate. It's made for stuff like that. It still takes time to hand fit valves but it can be done.
Old 11-26-2021, 10:06 AM   #5
Redbird
Redbird's Avatar
Try some real fine sand paper or emery cloth.
Redbird is offline   Reply With Quote
Old 11-26-2021, 10:35 AM   #6
nkaminar
nkaminar's Avatar
I would go with the Timesaver, yellow color is for soft materials like brass. Then lube with EZ Turn available from Langs: https://www.modeltford.com/item/2902LUB.aspx. This lubricant is a grease that does not dissolve in gasoline. It will help seal the petcock and make it easier to turn and help to keep it from wearing out again.
Old 11-26-2021, 10:55 AM   #7
Ruth
After you get it to seal again I recommend you install a gas tank screen (pencil filter). https://www.snydersantiqueauto.com/p...9346&cat=41707
Ruth
Old 11-26-2021, 01:03 PM   #8
katy
katy's Avatar
IIRC, Tom W recommended using toothpaste for a lapping compound on fuel shutoff valves.
Old 11-26-2021, 04:31 PM   #9
Synchro909
Synchro909's Avatar
If the scoring is minor, as you say, this will do the trick. I've posted about this one I don't know how many times.
https://www.snydersantiqueauto.com/p...9345&cat=41707
Old 11-26-2021, 04:48 PM   #10
Ruth
I have found this kit works good on an original valve, repros not so good. Most repros I have seen have "o" rings, not packing.
Ruth
Old 11-26-2021, 06:01 PM   #11
Russ/40
Russ/40's Avatar
Can you tell me if these repair kits work with the repo valves now being sold?
Old 11-26-2021, 07:35 PM   #12
Ruth
See post #11?
Ruth
Old 11-26-2021, 10:04 PM   #13
Synchro909
Synchro909's Avatar
The OP didn't say anything about it being a replacement valve. I've never seen one of those so I can't comment either way.
