Old 06-11-2020, 09:23 AM   #1
29Blue
Default Water Pump Removal
Searched for answer with no luck. About to remove water pump which has the replacement bolts instead of original studs. Will pump come out without moving radiator forward. 29 tudor. Thanks
29Blue is offline   Reply With Quote
Old 06-11-2020, 09:58 AM   #2
Russ/40
Russ/40's Avatar
Default Re: Water Pump Removal
I cant imagine that. Removing the stud/bolts will not totally eliminate the need to tilt the radiator forward, as the impeller needs to clear the head.
Old 06-11-2020, 10:44 AM   #3
29Blue
Thanks Russ/40 that's what I thought but a post I read said nothing had to be loosened. I have never done this before so I will move rad forward.
Old 06-11-2020, 10:45 AM   #4
johnbuckley
johnbuckley's Avatar
if it's a 4 blade fan "No ( unless you can unbolt the blades from the hub) " .If it's a 2 blade fan then there's a good chance that you will not need to remove the rad. But sometimes it is necessary just to tilt it a little ...Put some cardboard on the fins to protect them, be prepared to undo the rods and top hose and just tilt the rad a smidgin .
Old 06-11-2020, 10:57 AM   #5
Brentwood Bob
The cardboard also will protect your knuckles. The radiator fins are knife edge sharp.
Brentwood Bob is offline   Reply With Quote
Old 06-11-2020, 04:07 PM   #6
29Blue
Thanks for replies , it's a original type 2 blade which I am changing to a 2 blade aluminum.
Old 06-11-2020, 04:13 PM   #7
jack99
Invest in Les Andrews repair manual. It contains such great step by step information.
jack99 is offline   Reply With Quote
Old 06-11-2020, 05:02 PM   #8
29Blue
Agree great book. I use mine whenever a repair or maintenance is necessary.
Old 06-11-2020, 05:06 PM   #9
hudson32700
I just replaced my original 2 blade fan with a cast aluminum one. It cleared the radiator easily with cardboard in place to protect the fins. Mine has the fake studs so the pump removal was no problem. (1931 Tudor)
hudson32700 is offline   Reply With Quote
Old 06-11-2020, 05:59 PM   #10
chrs1961815
chrs1961815's Avatar
I would take the hood off and take off the support rods which will allow you to tip the radiator. You don't have to take hood off if you are very careful btw.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 06-11-2020, 06:09 PM   #11
Bill G
Bill G's Avatar
I recently changed to a HC head and had the hood, the hood rods and the upper radiator hose off. I took the water pump off and back on, both times with the head on the engine. In both cases, I did have to tip the radiator forward and also had to take the rock guard off to get the clearance. PS: I also used cardboard.
Old 06-11-2020, 06:31 PM   #12
Synchro909
Synchro909's Avatar
Over the years and several Model As, I have had water pumps in and out many times. I have not once had to move the radiator forward with a 2 blade fan or one of those plastic 5 blade jobs. The first thing I did was to replace the studs with bolts (decades ago).
Old 06-12-2020, 04:34 AM   #13
Bruce of MN
Bruce of MN's Avatar
I have one of these https://www.brattons.com/hood-prop-kit.html and it hold the hood up while I tilt the radiator forward to gain clearance.
Old 06-12-2020, 06:54 AM   #14
Ray64
Ray64's Avatar
I just put a leak less pump on mine last week. Got the fake bolts on there and the whole thing came out with no problem. Going back on was another story, Had to take a very minimal amount off of impellers to put it back in .Some times people take a little off anyway to slow the water down to prevent over flow in the rad. Just my take on it and what worked for me. RAY
Ray64 is offline   Reply With Quote
Old 06-12-2020, 11:32 AM   #15
Ruth
Originally Posted by Ray64 View Post
I just put a leak less pump on mine last week. Got the fake bolts on there and the whole thing came out with no problem. RAY
So, does your leak less water pump leak less than the one you that was leaking? That is kinda of a oximoron, isn't it? Even a leakless one sounds like it would still leak.
Sorry, self isolation is getting to me.
Ruth
Old 06-12-2020, 12:14 PM   #16
Russ/40
Russ/40's Avatar
You have to disengage the hood prop rods to tilt the radiator forward. You trust that situation to hold the hood while tillting the radiator forward?
I just dont understand how people can claim to not move the radiator and still take the pump out. I have 5/8" max, between the pump shaft and the radiator, the pump has to move forward 2 1/2" to clear the head. I realize you get some angle help, but not 2 1/2".
Old 06-12-2020, 04:49 PM   #17
Bruce of MN
I unscrewed the adjuster nuts to the maximum, so the rods were always supported at both ends. That was enough to get the pump in and out.
Old 06-12-2020, 09:27 PM   #18
Russ/40
Russ/40's Avatar
Gotcha, how close is your pump shaft to the radiator core?
Old 06-12-2020, 09:28 PM   #19
Fred K OR
It also may depend on the type of radiator you have. My radiator is a heavy duty one and the water pump nut up front if 1/8 inch from the radiator. But never had it overheat!
Fred K OR is offline   Reply With Quote
Old 06-13-2020, 07:04 AM   #20
1931 flamingo
1931 flamingo's Avatar
When I did it years ago I loosened the rods, used a short piece of wood to support the hood (from head to hood), simple.
Paul in CT
