04-04-2021, 04:46 PM | #1 |
Very Firm Brake Pedal
Happy Easter,
So, any ideas for why after bleeding my 1940 3/4 ton brakes I have such a firm pedal that it hardly moves at all? I rebuilt the master cylinder, fixed a few leaks, used speed bleeders for the bleed. I did not remove the hubs to check or adjust anything since I did not have the proper hub remover. I did not adjust the pedal rod. Brake pedal spring is in place. Thanks. Dale |
04-04-2021, 05:21 PM | #2 | |
Re: Very Firm Brake Pedal
04-04-2021, 05:26 PM | #3 |
Possible that the brake hoses are clogged/collapsed on the inside.
04-04-2021, 05:40 PM | #4 |
Adjust the brake pedal rod!!
x2
04-04-2021, 07:05 PM | #5 |
take it for a ride it may be ok
04-04-2021, 08:16 PM | #6 |
04-04-2021, 08:17 PM | #7 |
04-04-2021, 08:20 PM | #8 |
04-04-2021, 09:22 PM | #9 |
the master cylinder rod should "rattle" or have a small amount of free play or otherwise every time you step on the brake it is building pressure and thus not releasing the brake
cylinders |
04-04-2021, 09:38 PM | #10 | |
released at bleeders then adjusted forsome free pedal travel. Dont drive it in this condition ie nil free pedal travel. Phil NZ |
04-05-2021, 06:21 AM | #11 |
Grab the brake rod and make sure you can move it in and out at least 1/16" or that it rattles like Alan mentioned above.
Glenn |
04-05-2021, 06:33 AM | #12 |
Like guys said about the master cylinder actuating rod. The plunger returns to be against a snap ring, which fully releases the pressure. It does not work right if that does not happen.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-05-2021, 01:22 PM | #13 |
Although probably not your issue, having brand new hoses doesn't guarantee perfection. I've seen them "necked down" in the middle of the hose, right
out of the box. (and these weren't offshore items either) Five other shops didn't catch the customer's problem, which was a massive pull to the left under braking. |
04-05-2021, 01:28 PM | #14 |
I agree with the previous advice of adjusting the pedal rod.
It's also possible that dorvedahl47pu has dragging brakes due to this situation...... which others have also indicated. |
04-05-2021, 08:04 PM | #15 |
you said you rebuilt the master cyl. are you sure you installed the check valve in the right drecation
04-06-2021, 06:35 AM | #16 |
This bulletin shows the master cylinder parts assembly.
