09-07-2020, 02:56 PM | #1 |
Recycle or sell?
Hi all,
I have a spare torque tube that I need to do something with. Is it worth selling or recycling? Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
09-07-2020, 03:29 PM | #2 |
Re: Recycle or sell?
Check with the Mitchell folks to see if they could use it for their overdrive.
Dick |
09-07-2020, 03:32 PM | #3 |
That is an idea.
Mike
09-08-2020, 09:11 AM | #4 |
Some have been used for collectors on home made exhaust headers .
09-08-2020, 09:20 PM | #5 |
I have scrapped a couple hundred of them in the last couple years. They never break, so nobody needs them.
09-08-2020, 09:39 PM | #6 | |
Root cause of the failure was at the pinion gear double tapered bearing race, which was slip-fit loose in the banjo housing. The spinning race ground its way forward about 1/4" into the back end of the torque tube. So you could say "why not just replace the torque tube, and the banjo housing, and the bearing race"? Because as the bearing race was making its way forward it turned a good chunk of the torque tube into powder, which got into everything, and messed up all those other parts. So Steve, when you say "they never break", I'm sure you mean "I've never seen a broken one". .
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
09-08-2020, 09:41 PM | #7 |
09-08-2020, 10:14 PM | #8 |
I hauled some to swap meets for years unable to sell at all!!
09-08-2020, 10:18 PM | #9 |
^^^ the same guys who scream 'save everything' walked right by^^^
09-08-2020, 10:23 PM | #10 |
I was going to post something like that!
