05-30-2020, 04:43 PM | #1 |
1937 roll out crank retainer clip
What does the retainer clip look like for the 37 car. I am using mine to roll the windshield in and out, but I have to retainer clip. All I could find so far is the clip for the door handle, and they were pins in 1937. Thanks
05-30-2020, 10:48 PM | #2 |
Re: 1937 roll out crank retainer clip
It's been a while since I saw mine, but think it looks like this, it holds the crank to the dash, not to the operator.
05-30-2020, 11:31 PM | #3 |
Attached is a pic showing the parts involved with the regulator mechanism. Hope this helps.
gregg |
05-31-2020, 08:24 AM | #4 |
Now to find them..
05-31-2020, 10:07 AM | #5 |
On one of my 37's I used a C-clip (see pdf). I wanna say it was 9/16" ID but best to measure the regulator shaft diameter to be sure. The spring washer I was able to find at Ace Hardware.
gregg Last edited by 1937sedandelivery; 05-31-2020 at 02:09 PM. |
05-31-2020, 10:23 AM | #6 |
05-31-2020, 12:41 PM | #7 |
Thanks.
05-31-2020, 04:50 PM | #8 |
Is it the spring washer between the handle and the dash, and the stop washer under the dash??
06-01-2020, 12:35 PM | #9 |
I have always "assumed" that both pieces are on the backside of the dash, but now that you bring it up, I am not 100% sure. BTW, the snap ring I mentioned earlier is 11/16", not 9/16".
Sidenote: there is a chromed finish trim piece that is on the front side of the dash. The handle itself rotates on this when opening/closing the windshield. Good luck finding that piece. gregg |
06-01-2020, 12:55 PM | #10 |
I may already have it. I can just slide a finger nail under something there. It looks like brass though..
06-01-2020, 03:42 PM | #11 |
The photos
06-01-2020, 04:39 PM | #12 |
06-02-2020, 02:22 PM | #13 |
I found some make shift parts. I found a 7/8" snap ring, and a metric wave washer. I have to bore out the washer just a little to fit. I will go somewhere else to find the 11/16" snap ring.
