04-17-2018, 10:09 AM | #1 |
CB radio question
[First off, I promise myself I will never, ever attempt to type in a (lengthy) thread again using my cell phone!! lol I was almost finished and the system 'burped' and I lost everything! Now on my desktop.]
My '31 Vicky is a 6 volt positive ground system. I can install a (modern) 12 volt CB using an inverter. That's not the problem. I know to insulate it from grounding on any metal (going to ground) in the car. I am running a separate ground wire from the inverter. Antenna. Herein lies the problem. While I can insulate the bracketry for the antenna, the car in its entirety is "positive." How do I create a ground plane? Touring groups may be spread out over 5 to 7 miles and I prefer not to have to relay up the line to the lead car, then have the response relayed back to me agin through the line. As I see it, without being able to create a ground plane, I will have VERY limited range broadcasting the CB. Okay you electrical "sparkles," what can I do?? Bill |
04-17-2018, 01:24 PM | #2 |
Re: CB radio question
The easiest solution that comes to mind is use a 5 watt handheld connected to the mobile antenna. Hang the radio on the windshield opening nut.
04-17-2018, 04:56 PM | #3 |
I have been looking for an inexpensive DC/DC 6V to 12V isolated inverter -- this would solve my problem; unfortunately, those I've found are very expensive.
Anyone know of somewhere where this item can be purchased inexpensively? Bill |
04-17-2018, 05:15 PM | #4 |
The low cost ones won't work with a grounded cb antenna. The $100 ones work fine. That is what our club members all use. The other option is a 12 motorbike battery. Charge it before each tour. There is a ton of info on this subject on the forum.
04-18-2018, 09:47 AM | #5 |
As a radio and RF engineer, I cringe at some of the CB setups I see in Model A's.
I was forced to acquire a CB for tours with one club, so I picked up one of those portable jumpstart boxes that has a sealed gel-cell inside and jumper cables, tire pump, cellphone USB charger, etc. Plugged the CB into the 12v outlet (cigarette lighter socket for those over 50), and used a bumper mounted antenna tuned for 1:1 SWR. That setup had the strongest signal in the group and I ended up being the relay for most longer distance traffic. The jumpbox battery has enough capacity to run the CB for a week or more on a single charge, so it wasn't an issue. Even though we no longer have the CB, we still take the jumpbox along on tours because the wife really likes having the USB receptacle to charge her iPhone. I like having the tire pump! |
04-18-2018, 01:38 PM | #6 |
Bill Neverhadaflat
04-18-2018, 01:48 PM | #7 |
Well Bill, that is at least a better answer than your earlier advice of 2 tin cans and a length of kite string❗
ROFL Other Bill |
04-18-2018, 09:41 PM | #8 |
I got my 10A power supply from eBay, $30. Case is isolated so no issues mounting it. Separate-/+ in and out.
