03-31-2021, 10:20 AM | #1 |
30-31 roadster seat adjuster
Getting ready to install the seat backrest in a 30 roadster. The seat adjuster has two positions that move the top of the backrest back an inch or forward an inch from the package tray. My question is which position is best? it only moves the top of the backrest about an inch, so does it really make much difference which position?
Thanks John |
03-31-2021, 10:49 AM | #2 |
Re: 30-31 roadster seat adjuster
You have a seat adjuster ? Hmmm.
03-31-2021, 11:37 AM | #3 |
That's what it's called at Mike's "A" Fordable and several other vendors. 31/31 Roadsters only. It attaches to the wood on the backrest and to the package tray.
03-31-2021, 01:10 PM | #4 |
How about showing a picture.
David Serrano |
03-31-2021, 01:42 PM | #5 |
Try it in both positions and see which one is the best for you.
Paul in CT |
03-31-2021, 04:11 PM | #6 |
03-31-2021, 04:13 PM | #7 |
Got a 31 Roadster, never heard of or have an adjustment on mine??
03-31-2021, 05:34 PM | #8 |
check your 2 piece package shelf. You should be able to see where the two metal pieces are fastened together using one of 2 sets of holes. It is probably covered by upholstery but you might see the bolts/nuts if you look at the bottom of the shelf from inside the trunk/rumble. These 2 pieces of metal are part#s 35050 and 35060 in Bratton's catalog or look on line at their website.
