Old 10-12-2020, 07:29 AM   #1
Phil Gillespie
Phil Gillespie's Avatar
Default Use of a Big 97 Stromberg Carb.
59a Flathead street use in a 46 Mercury. New build.
bored 3 5/16 with a 53 Mercury camshaft grind.
presently running single stromberg 97 carb.
For this set up is a" Big Stromberg 97" ok for this set up or too big.
Or to just stick with standard stromberg 97. with 46 jets.?
Thinking about a new carb to go with new engine rebuild.
Thanks Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 10-12-2020, 08:15 AM   #2
uncle max
uncle max's Avatar
Default Re: Use of a Big 97 Stromberg Carb.
Not the best choice!
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 10-12-2020, 08:21 AM   #3
Phil Gillespie
So to stick with the standard Stromberg 97 then?
Phil NZ
Old 10-12-2020, 11:10 AM   #4
Russ/40
Russ/40's Avatar
Try running a Stromberg 48, a little bigger.
Old 10-12-2020, 11:30 AM   #5
35fordtn
35fordtn's Avatar
Max what’s your thoughts on these big 97’s I’ve heard good and bad about them. I planned to use one in a 4” mercury crank motor but haven’t yet.
Old 10-12-2020, 11:42 AM   #6
scicala
scicala's Avatar
Or use a Holley 94 like originally came in the car.
Sal
scicala is offline   Reply With Quote
Old 10-12-2020, 11:49 AM   #7
tubman
tubman's Avatar
I would think that any engine of Mercury size (255 ci) and up would benefit from a larger carburetor. Mercury had the larger four bolt Holley's from the factory. If your going for a totally stock restoration, it's one thing, but for a driver, I would think it would be a benefit. I have a Rochester 2G on a bored out Merc manifold on the warmed over '51 Merc in my car and am very satisfied with it. The Mercury engine, a set of Edmunds heads, a Mallory dual point and the Rochester carb gave a noticeable increase in performance in my case.
Old 10-12-2020, 04:09 PM   #8
Lawrie
Lawrie's Avatar
You have to bore out the manifold to match the big97, and on the spare 33 eng (276) I had to use an 8ba manifold, then the fuel pump mount needs mods ,then the gen wont fit, need mods to the vac brake line, etc.
I have only run it on the engine stand and don't think I will run it in the 33.
Lawrie
Old 10-12-2020, 04:34 PM   #9
scicala
scicala's Avatar
I think the Mercury is a '46, so it would still have the 239 engine. But a slightly larger carb ain't gonna hurt.
Sal
Old 10-12-2020, 05:00 PM   #10
tubman
tubman's Avatar
Sal
He said a 3 5/16" bore, which yields 258ci, and is actually bigger than a later stock Mercury. I have bored several Mercury manifolds to the proper size (both aluminum and cast iron) and never had a problem; I don't know about the earlier manifolds.
From my experience, I believe that a 2G is superior to the older Holleys.
Old 10-12-2020, 05:44 PM   #11
Phil Gillespie
I'm not wanting to modify too much. So to go maybe with a new standard sized Stromberg 97 and go with 46 jets. I've spent the money on the engine build and just want a new carb to finish it off. The Strombergs are available in NZ without the 2 to 3 months covid 19 delays. Appreciate all input and advice.
Phil NZ
Old 10-12-2020, 11:14 PM   #12
Brian
Brian's Avatar
Phil, Why are you saying .046 jets?
97's were used 36-38 on 221's.
I have a couple of original issue 97's; these have '67' cast into them which tells they are original issue on 36 commercial vehicles. These original carbs are also stamped with the main jet size. One has .045, the other .046. So, these are how they came from the factory, jetted to suit 221's. You may want to jet up a bit I think?
Old 10-12-2020, 11:33 PM   #13
Phil Gillespie
Yes Brian. My 39 coupe is running a Stromberg 97 jetted at 46.
Its a 221 plus 80 thou. This was checked on a dyno and needed to go from 45 to 46 as little lean at top end.
So with the single 97 at the 258 cu maybe around a 48 but to stick with 65 pv.
Just getting this engine fine tunned. Running NGK 6L and these are looking good at present set up. ie 97 carb jetted 46.
Phil NZ
Old 10-13-2020, 09:00 AM   #14
Ol' Ron
Ol' Ron's Avatar
I ran a 2GC on an early 33/34 intake on our stockcar. Had to sleeve the bore and fill the PB vacuum with JB weld for the center intake bolt. Ran great. I would alsosuggest a modified GM distributor as well. A well tuned engine woll last longer and provide economical service.
Gramps
Old 10-13-2020, 03:52 PM   #15
Ian NZ
Ian NZ's Avatar
what should a Stromberg 48 carburettor be jetted too for a 221C.I Fords V8 engine.
Ian NZ is offline   Reply With Quote
Old 10-13-2020, 08:48 PM   #16
Phil Gillespie
So will stick with the standard Stromberg 97 and jet up to suit as required as per spark plug indications. NGk B L 6.
always appreciate all comments and advice received..
Phil NZ
Old 10-13-2020, 09:42 PM   #17
tubman
tubman's Avatar
I still think a bigger carburetor would be appropriate for a 258" engine with an upgraded camshaft.
Old 10-13-2020, 09:51 PM   #18
Brian
Brian's Avatar
Ian; 0.048in main jets and a Number 63 power valve
Old 10-13-2020, 10:50 PM   #19
Ol' Ron
Ol' Ron's Avatar
Use an AF meter to get the best AF. Plug reading doesn't work anymore.
Old 10-14-2020, 09:10 AM   #20
Charlie ny
Phil,
Rule of thumb from a long time ago is go up no more than two size or ' risk '
upsetting a/f numbers. I slipped a 48 bowl between 97 air horn and base and used #50
jets and a #60 pv to run my '32 p/up...286 cu in....it runs wicked good. I've got some
48 bowls..get back to me at [email protected] if you wish.
Charlie ny
