Old 03-25-2020, 01:54 PM   #1
uncle buck
uncle buck's Avatar
Default Columbia 2 speed A-7 differential baffle
Can someone please post a picture of a A-7 differential carrier baffle? Also how it looks installed? It looks like a ring in the heavy cast iron adapter.
Thanks
File Type: jpeg F0643A6B-2673-4FFC-84FD-A8437C518056.jpeg (25.7 KB, 62 views)
uncle buck is offline   Reply With Quote
Old 03-25-2020, 04:51 PM   #2
solidaxle
solidaxle's Avatar
Default Re: Columbia 2 speed A-7 differential baffle
You're in luck I happen to have mine apart. It's just pinched in there.
solidaxle is offline   Reply With Quote
Old 03-25-2020, 08:32 PM   #3
uncle buck
uncle buck's Avatar
Thanks @Solidaxle , can you show me how it fits in the housing? I have several boxes of disassembled parts I am trying to lay out
Old 03-25-2020, 09:46 PM   #4
uncle buck
uncle buck's Avatar
Ok I see how goes, had to get a second casting to study. Thanks for your pictures to give an idea what it is.
File Type: jpeg 091A804B-CF10-46BB-84CC-A1FA17FD2E8E.jpeg (31.3 KB, 68 views)
File Type: jpeg F64CEDD0-71BB-4C7E-803D-958588A0B852.jpeg (26.2 KB, 56 views)
Old 03-25-2020, 10:47 PM   #5
deuce_roadster
deuce_roadster's Avatar
If I remember correctly, it is staked into the casting. I had 1 casting that it was missing from.
Old 03-25-2020, 11:02 PM   #6
uncle buck
uncle buck's Avatar
It appears so. I have one it is missing from also, but fortunately I had an extra that had it too. I didn't visualize it being that big around and I had nothing like it loose in my boxes
Old 03-26-2020, 07:46 AM   #7
solidaxle
solidaxle's Avatar
You must know John at Columbiatwospeedparts.com, He's the expert on these things.
Old 03-26-2020, 08:29 AM   #8
uncle buck
uncle buck's Avatar
Yes, he did his bulletproofing treatment. When I got unit, it was apart and everything was in boxes with a mixture of stuff that doesn't belong. I have been studying the exploded view and trying to sort through everything to take to a friend to be assembled. Thanks for your help
Old 03-31-2020, 11:46 AM   #9
Highboy34
What's the function of that baffle?
Highboy34 is offline   Reply With Quote
Old 03-31-2020, 02:50 PM   #10
Terry,OH
Terry,OH's Avatar
The rotating A-17 assembly has paddles on the outside that take the oil and direct it into the A-6 oil passage. This is how the bearing, planetary gears and shafts plus the sun and the clutch get their necessary oil. The A-7 baffle help to hold the oil in place for the paddles on the A-17.
