Old 04-02-2021, 05:41 PM   #1
GT1929
Default Ammeter - Needle
Need picture of how needle fits in orginal ammeter.
GT1929 is offline   Reply With Quote
Old 04-02-2021, 11:18 PM   #2
Dan Partain
Dan Partain's Avatar
Default Re: Ammeter - Needle
Original Ammeter
Dan Partain is offline   Reply With Quote
Old 04-03-2021, 12:54 AM   #3
redmodelt
redmodelt's Avatar
What exactly do you need to know?
Old 04-03-2021, 06:31 AM   #4
rotorwrench
rotorwrench's Avatar
This link to Vince's site has good photos.
http://www.fordgarage.com/pages/ammetertool.htm
The ammeters were about the best product for the price ever made. It's too bad that most of the reproductions aren't as sensitive as the originals. The freedom of needle movement was excellent on the old originals but modern reproductions, not so much.
Old 04-03-2021, 07:53 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
The needle is part of a D'Arsonval Movement which reacts to the magnetic field around the horseshoe shaped bar when current flows through the bar. The movement is very sensitive, so any change in friction or unbalance of the centering springs will cause the ammeter to have an erroneous reading. This is a job for someone with the steadiness of a watch maker or jeweler. My recommendation is to find a better gauge.
Bob Bidonde
Old 04-03-2021, 09:06 AM   #6
dpson
dpson's Avatar
The newer reproduction ammeters are basically junk. If you tip it forward the needle falls off and you have to pull the cover off to put it back on. It's too bad they bother to make this junk. Even the vendors don't like them, but they are all that's available right now as far as I know.
dpson is offline   Reply With Quote
Old 04-08-2021, 12:08 AM   #7
GT1929
The needle doesn't appear to have a hole in it so I guess it just gets squeezed between the two pieces?
Old 04-08-2021, 11:01 AM   #8
rotorwrench
The needle should be attached in some way to the spindle of the rocking armature or it could slip on the spindle and not return to the zero indication.
Is this a reproduction ammeter?
Old 04-08-2021, 05:19 PM   #9
redmodelt
redmodelt's Avatar
Designs changed over the years. Could look original but might be a replacement. While I am not sure, could have been more then one company making the meters for Ford. If it has Ford on the face, it is not original. It would be a replacement/aftermarket. Suggest posting a photo of what you are working on so everyone can be on the same page.
Old 04-08-2021, 08:04 PM   #10
whirnot
whirnot's Avatar
Has anyone used the Ammeter that nurex sells? Pretty spendy at $80 but they say it's US made.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-09-2021, 09:00 AM   #11
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Bill, I have not tried them as I felt these were old NORS units and not something they were manufacturing today. The initial turn-off for me was the number plate was incorrect along with the plating, but for someone that was needing a quality 30-30 meter instead of a 20-20, then they would likely be a value.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-09-2021, 09:31 AM   #12
Badpuppy
If there's more than 15A through the meter either direction there's something wrong. It measures only battery current. 20-20 is appropriate for any model A vehicle, unless the wiring has been modified.
Badpuppy is offline   Reply With Quote
