Old 04-27-2021, 10:42 PM   #1
backrodebob
backrodebob's Avatar
Default Pertronix Nightmare
Read a lot of pros and cons about Pertronix, had to see for myself. 1st one come in look like someone tried to install , wires cut! sent it back!! 2nd one installed NO SPARK! contacted customer service, this guy I talked to is in the wrong business! pretty much said I didn’t know what I was doing, that I installed it wrong, finally got him to email me how to bench test the unit. needless to say the unit tested bad. they say the third time’s the charm, not in this case! When it came in I benched tested it and it test good, finally!! Installed and it fired up, ran for about 5 minutes then died??? sent it back and back and staying with “POINTS”
backrodebob is offline   Reply With Quote
Old 04-27-2021, 11:02 PM   #2
50fordcoupeman
50fordcoupeman's Avatar
Default Re: Pertronix Nightmare
Have had perfect luck with two sets...............
50fordcoupeman is offline   Reply With Quote
Old 04-28-2021, 03:14 AM   #3
koates
Pertronix units are very reliable on 12 volt cars. What car are you running it on and what voltage? Ignition coil must be a match for the Pertronix unit. If the coil pulls to much primary current then the Pertronix unit could be damaged. I think you have other issues apart from the Pertronix unit. Regards, Kevin.
koates is offline   Reply With Quote
Old 04-28-2021, 05:52 AM   #4
chuck stevens
chuck stevens's Avatar
I have never been left along the road with a set of points!!!
chuck stevens is offline   Reply With Quote
Old 04-28-2021, 06:53 AM   #5
millersgarage
millersgarage's Avatar
Never had an issue with Pertronix
millersgarage is offline   Reply With Quote
Old 04-28-2021, 07:46 AM   #6
Ford Freak
Over the yrs. I have had Pertronix in a half dozen various cars w/no problems.
They were all 12 volt, used correct Pertronix coil, & were the "Igniter 2" model. - F F
1952 Ford F1
1965 Ford Falcon Sprint
2007 Ford Mustang GT
Ford Freak is offline   Reply With Quote
Old 04-28-2021, 07:50 AM   #7
325w
Used one in a GM distributor. Used the coil they said. Coil got so hot you couldn’t touch it. Contacted GMC buba. He told me to use a ballast resistor. Car was sold and still doing fine.
325w is offline   Reply With Quote
Old 04-28-2021, 08:09 AM   #8
chap52
chap52's Avatar
Ran Petronix in my 52 truck(12 vv-t) for 15 years and only had one "suspected" issue. Called them and the guy I spoke with helped me zero in on the real problem and all went well fo the next 14 years... Just like buying bananas some look good on the outside and then.... Chap
Old 04-28-2021, 08:15 AM   #9
Frank Miller
Frank Miller's Avatar
Tell me how you get that condenser going. Why I switched. Brand new echlin completely quit on me. Good thing I was home.
I was never a fan of pertronix until I started getting bad condensers. Figure if I had to run questionable stuff go with something that does not need adjusting.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 04-28-2021, 08:33 AM   #10
Charlie ny
Re: chevy dists converted to 8BA....any customers who wish electronic ign over pts & cond I request they order the Pert and forward it to me so the warranty is in their name.
I strongly recommend the HALL effect version the reads the breaker cam lobes and
not the unit that uses a relucter ring. I use the NAPA coil 12v IC 14 2.8 ohm.
Charlie ny
Old 04-28-2021, 10:50 AM   #11
Veeder
I stronfly suggest points especially if you want to use the stock coil. The Dwell period with a pertronix unit is about 50/50 on a helmet distributor.
I actually believe the reason they want you to use the ignitor coil (especially with 6 volt systems) I'd because of the dwell period.
But as always I could be wrong but I had one unit fail and have gone back to points.
Bob l
Veeder is offline   Reply With Quote
Old 04-28-2021, 10:57 AM   #12
38bill
38bill's Avatar
Just wondering what are you guys running for plug wires?
38bill is offline   Reply With Quote
Old 04-28-2021, 11:23 AM   #13
backrodebob
everything was installed according to there tech department?? what else can I say!
Old 04-28-2021, 11:42 AM   #14
tubman
tubman's Avatar
Packard 440 and Rajah spark plug terminals (from "The Brillman Co.").
Old 04-28-2021, 11:55 AM   #15
51 MERC-CT
51 MERC-CT's Avatar
With Pertronix ignition on an 8BA, 7mm Spiral wound wire to help prevent radio interference to the electronics as per Pertronix.
Old 04-28-2021, 02:40 PM   #16
Ronnieroadster
Ronnieroadster's Avatar
Pertronix has worked perfectly in every one of my cars for years. Pertronix conversions are used in the many vintage engines we run that have set numerous Land Speed Records.
Many customers have also had excellent success with the Pertronix conversions. HOWEVER the Pertronix unit will die if there's a short in the cars wiring. Its shocking your so unsuccessful with the conversion.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 04-28-2021, 06:19 PM   #17
1948F-1Pickup
1948F-1Pickup's Avatar
Pertronix have the same reliability issues they had 30 years ago
when they were called PerLux. Solid state electronic stuff doesn't like
intense searing heat, like what you find inside a distributor. Electronic devices
like good grounds and you may not have good ones with a distributor.
Those are my basic issues with Pertronix.
To those that have had good fortune with their stuff I say good for you.
My experience has not been that positive.
1948F-1Pickup is offline   Reply With Quote
Old 04-28-2021, 07:15 PM   #18
Bob T
No problems in three different cars. One is over 25 years old
Bob T is offline   Reply With Quote
Old 04-28-2021, 07:57 PM   #19
drolston
drolston's Avatar
Fried my Petronix while troubleshooting that turned out to be bad spiral wound ignition wires. I went back to points and copper ignition wires. Tubman condenser to insure against that crap shoot of reliability. The all copper wires setup completely jammed my satellite radio. Switched out the one foot coil to distributor high tension cable to spiral and got my radio back. Evidently it does not take much length of spiral wound to suppress the static. Runs great.
Old 04-28-2021, 08:15 PM   #20
tubman
tubman's Avatar
I had the same experience. Had ignition interference in the radio with all Packard 440. Replaced the coil wire with suppression wire and problem solved. You wouldn't think it would have made that much difference, but it did.
