Old 04-21-2021, 02:54 AM   #1
Rob Doe
Default How do you all test for an intake manifold air leak?
What are some of the methods you all use? What do you spray around the manifold, starter fluid(some percent ether), brake cleaner, WD40?
I'd like to be as safe as possible.
Rob Doe is offline   Reply With Quote
Old 04-21-2021, 06:50 AM   #2
Big hammer
Default Re: How do you all test for an intake manifold air leak?
DO NOT USE BRAKE CLEANER---------------- The gas cloud it produces could kill you!!! I've used carb cleaner in a spray can and the little tube pointing it around the flange
get a bigger hammer tap done
Old 04-21-2021, 07:20 AM   #3
BTERRY29
BTERRY29's Avatar
Starter fluid will do the trick to
BTERRY29 is offline   Reply With Quote
Old 04-21-2021, 07:44 AM   #4
Jack Shaft
the wifes hairspray...and as an added benefit it will hold for hours with a pleasant scent
Old 04-21-2021, 07:46 AM   #5
john charlton
john charlton's Avatar
WD 40 worked very well for me . Sprayed it between the block and manifold from the top The engine did an instant speed up ..
John in lovely spring weather Suffolk County England .
Old 04-21-2021, 07:47 AM   #6
john charlton
Old 04-21-2021, 07:52 AM   #7
Jack Shaft
you can say that again John
Old 04-21-2021, 08:52 AM   #8
jayvee34
jayvee34's Avatar
That is the method I have used over the years. Very effective if you have a
vacuum leak at the intake manifold.
jayvee34 is offline   Reply With Quote
Old 04-21-2021, 09:20 AM   #9
Garwood
Garwood's Avatar
I just assumed I had a leak since it felt under powered and I felt a little light headed after driving a few miles. So I just spent an afternoon replacing the gasket. Really isn't that hard. After it was replaced I notice more power and she can drive a little faster.
Garwood is offline   Reply With Quote
Old 04-21-2021, 09:22 AM   #10
Y-Blockhead
Y-Blockhead's Avatar
An unlit propane torch. Leaves no residue.
Old 04-21-2021, 09:31 AM   #11
old31
I have tried all of the above methods and the best for me is Blockheads way. No residue, drips, fires.
But unlike Jacks method I would not be caught dead with my wifes hairspray in my tool box! My wifes red nail polish in my toolbox is bad enough. (great for marking objects)
old31 is offline   Reply With Quote
Old 04-21-2021, 01:03 PM   #12
Jack Shaft
Look,I'll wear the fishnets but I won't belt out show tunes on demand...nope,not anymore
Old 04-21-2021, 05:21 PM   #13
Neshkoro
Neshkoro's Avatar
Blockhead, what does the unlit propane do? Does the engine speed up if there is a leak?
It sounds like an easy and clean way to test!!
Neshkoro is offline   Reply With Quote
Old 04-21-2021, 05:53 PM   #14
Synchro909
Synchro909's Avatar
If you are using a flammable spray of any kind to locate a leak, Rig up a flexible hose for an air intake well away from the carburettor. I use a length of vacuum cleaner hose and duct tape. It doesn't have to be very big diameter - the engine is only idling. You need to draw air from well away from the volatile spray or the carb will suck some in and give a false response. Just my experience.
Old 04-21-2021, 06:47 PM   #15
Y-Blockhead
Yes the propane is sucked into the intake thru the leak and the engine speeds up just like any of the other methods using a flammable gas or liquid. Just no mess. I have used those micro-butane torches also.
And as Synchro pointed out, you don't want to point it towards the carb inlet.
Old 04-21-2021, 06:54 PM   #16
Gene F
Gene F's Avatar
I was thinking about fire risk too. I think I'd opt for a can of WD-40 with a nozzele in one hand, and a garden hose in the other hand. I have been in a fire before, and I tend not to take it lightly.
Old 04-22-2021, 08:32 AM   #17
Bob Bidonde
Bob Bidonde's Avatar
Try this easy test technique:
Bob Bidonde
Old 04-22-2021, 09:51 AM   #18
nkaminar
nkaminar's Avatar
A completely different technique is to use a small diameter rubber hose. Hold one end near your ear and the other at the suspected leak location. If you hear a hissing sound, that is where the leak is.
Old 04-22-2021, 09:51 AM   #19
alexiskai
alexiskai's Avatar
Is there a central internet repository for Bob Bidonde infographics? If not, we really need one.
Old 04-23-2021, 04:27 PM   #20
Benson
Benson's Avatar
Try this:
https://www.modelalongisland.com/technical
