01-30-2023, 05:58 PM | #21 |
Re: What 12 volt battery and where ?
@Eagle - There is a de-sulfater to pep up lead-acid batteries:
https://www.thermoil.com/ The company also has an oil which is meant to trap the hydrogen as it is released thereby preventing it from escaping and causing corrosion etc. By the way, “snake oil salesmen” had a bad reputation because their products were not actual snake oil, but cheap who-knows-what. Real snake oil was believed to have restorative powers.
David in San Antonio 1930 ('31?) Deluxe "Wretched Roadster" Restored 1957 Alamo A’s Club Last edited by David in San Antonio; 01-30-2023 at 05:59 PM. Reason: Edited for typing error |
04-13-2023, 01:02 PM | #22 | ||
I would like to revive this post if possible. ) For those who have successfully used this Thermoil, how have you typically installed the Thermoil? Is the requirement plan to first find a battery that has a removable top? I recently went thru this on a battery that I needed to only add water however I was unsuccessful in finding a way to get the top off.
. ♦ Prices do not include Shipping/Freight. ♦ Buyer is to pay for shipping charges. ♦ Check or Money Order is preferred as payment. ♦ If you have questions, please PM me!! |
04-13-2023, 06:08 PM | #23 |
Maybe you can send a message to YBlockhead. He says he uses thermoil (see page 1 of this thread)
David in San Antonio 1930 ('31?) Deluxe "Wretched Roadster" Restored 1957 Alamo A’s Club |
04-13-2023, 06:53 PM | #24 |
12 Volt lithium ion batteries for starting cars are starting to come on the market. They should last a lot longer and are maintenance free. They are expensive so only buy them if you intend to keep your car for a long while.
Here is just one I found with a Google search: https://www.lifepo4battery-factory.c...rting-battery/
A is for apple, green as the sky. Step on the gas, for tomorrow I die. Forget the brakes, they really don't work. The clutch always sticks, and starts with a jerk. My car grows red hair, and flies through the air. Driving's a blast, a blast from the past. Last edited by nkaminar; 04-13-2023 at 07:03 PM. |
04-13-2023, 11:22 PM | #25 |
Good price on Batteries at Walmart. Oops, some one already said that.
The Master Cylinder Enjoying life at the beach in SoCal... |
04-13-2023, 11:33 PM | #26 | |
04-14-2023, 06:30 AM | #27 |
Add thermoil to your battery they last 10 -15 years. it was made for golf carts.
04-14-2023, 08:05 AM | #28 |
As a added word of caution, I installed a group 25 also. The top posts are on the transmission side with the + towards the front. I found the + cable clamp dangerously close to the hold down plate so I cut a piece of inner tube that went around the post and extended over the plate to prevent any possibility of shorting.. No problem with cable length.
Warren |
04-14-2023, 09:22 AM | #29 | |
04-14-2023, 09:54 AM | #30 | |
04-14-2023, 12:10 PM | #31 |
When I look at the Group 25 battery in the photo in Post #20, I see the battery posts are both on the frame side of the battery box.
I think it is better to have the battery posts on the transmission side. That gives a straight shot for the starter cable to pass up to the post on the starter switch. Have you looked at a Group 34R battery? It seems to be the same size. See photo. 10" long 6.88" wide 7.63" high Then the posts are both on the transmission side. The positive post is toward the front. Getting a ground cable over to the ground post of the battery is easy, especially if you are going to add a ground disconnect switch.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
04-14-2023, 02:20 PM | #32 |
