Old 05-13-2013, 12:08 PM   #21
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Restoring Spindle Arm and Steering Gear Arm Balls...
Originally Posted by John Stone View Post
I have 4 sets of Grady's balls on my cars. First set was 1978. Of course around Wichita we have certified welders (aircraft you know). I think he is uses case hardened balls. He has taken some and tried to break off the ball with a sledge hammer but only bent the arm.
Locally we always say that Grady has a great set of balls.
Well, tell Ol' Grady to quit "GLOATIN' Buster T.
"THE ASSISTANT GURU OF STUFF"
Old 09-04-2013, 03:48 PM   #22
[email protected]
modela@aol.com's Avatar
Originally Posted by Steve Plucker View Post
How many of you feel comfortable in replacing/restoring the balls on the Spindle Arms and the Steering Gear Arm?
During my neophyte days of Model A Restoration (1966-68), I sent my Spindle Arms and Steering Gear Arms off to have "new" balls put on.
When I got them back, they looked great. Fast forward to 1980 when I drove my 1929 Standard Coupe back from a trip to California and as I was just entering Bend, Oregon, I lost my steering! I almost soiled my britches on that one!
Pulled into a gas station at the point of no steering and discovered the ball had seperated from the Steering Gear Arm. Using my MAFCA Roster at the time I called someone and they got me a Steering Gear Arm so I could coninue my trip back to Walla Walla, WA.
From that point on, I have always tried to find good and unworn originals.
Anyone ever had an experience like that with those "reconditioned" Spindle Arms and Steering Gear Arms?
Even if you have done the job yourself...do you really feel comfortable?
Pluck
I must weigh in on this Steering Pitman Arm re-ball issue as well. Our safety in these old Model A's should always be the number one priority.
I also purchased a re-balled steering pitman arm well over 20 years ago and have run it on my coupe without ever giving it a thought. Lots of tours and lots of miles and I can't recall which Model A vendor I purchased it from since it was so long ago. It was just reballed one and not on of the modified /shortened ones...
Leaving on August 21, I was going to drive my coupe on the GAMARAI 2013 tour around Iowa with the Central Iowa Model A Club. It would be approximately a 900 mile round trip for me so I prepped my car for the tour and also went over all of the steering components to grease, adjust, and tighten everything. All looked well for this tour..
On the morning I left for this tour, I was driving to get to the bottom of my driveway and suddenly noticed I had "power steering". Since I didn't recall ever installing power steering, I stopped the car and looked under it to see that the ball had separated from the pitman arm!!!. The back side still had paint on it so from one side it still looked fine.
I had an old original one in my garage that I was able to quickly swap out and get going down the road. I never thought to put an extra pitman arm in my car with my other repair items so it could have been a major break down on the road. But the scary part is what would have happened to us on the tour on those long steep hills and high speeds if it would have happened later. Who ever was watching out for us that day, Thank you....
Luckily I had the happy ending version and we went on the GAMARAI 2013tour and had a great time with the Iowa folks and also a few folks from Illinois and Indiana as well... Met some nice Ford Barners as well on the tour...
PLEASE anyone who has purchased at any time in the past a re-balled unit, PLEASE double check these re-balled pitman arms. Take it off the car and hit it with a hammer to hear it ring. This pitman arm looked fine right up until it separated that morning.
I wire brushed off the paint on the back side of the pitman arm and shot this picture to show how this happened to this particular one...
modela@aol.com is offline   Reply With Quote
Old 09-04-2013, 06:49 PM   #23
Don S
I had a similar escape from disaster . We were at a show in town. The merchants wanted us to park on the wide side walks. When I drove off the side walk I had no steering. The welded on ball had probably broken when I backed over the curb.Really lucky,just parked and got a tow home.This was 20 or so years ago. New ball and studs were available with threaded ends and pinned nuts complete with tapered shaft to fit.Still on, no worries. Doesn't look original but that's ok with me.
Don S is offline   Reply With Quote
Old 02-09-2023, 10:34 AM   #24
tgreen03
I called him and he no longer does this work, retired
tgreen03 is offline   Reply With Quote
Old 02-09-2023, 02:02 PM   #25
Pete W.
Another vote for Wiley Higgens! He's quick and the best, nice guy too.
I also had a pitman ball problem at 40 mph in a curve
Pete W. is offline   Reply With Quote
Old 02-09-2023, 08:48 PM   #26
Pete
Pete's Avatar
Several years old thread but advice on NOT repairing steering balls is always good.
Welding of any kind on steering parts not a good idea. Most of that kind of repair is done in back yard shops and heat treat can never be controlled. There are cases where welded steering parts resulted in accidents and the insurance companies denied claims.
Many people are willing to play russian roulette with saftey stuff but they seldom think of the guy in the other lane.
The best repair is to drill out the old balls, put a 7 degree taper in the hole and use a 3/4-16 early Ford truck tie rod end on both ends of a piece of DOM tubing.
If you need it to look stock, find some good usable original parts for your judging type car.
Just a side note. No welding is allowed on steering parts by any sanctioned racing venue.
Old 02-09-2023, 08:55 PM   #27
chrs1961815
chrs1961815's Avatar
The best way is the way A&L does it - turn the ball down and a sleeve is put on. Welding a new ball in is not safe enough for my comfort, especially on a pitman arm.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 02-15-2023, 06:26 PM   #28
Model "A" Fords
DIY steering ball repairs. In the tool & die and stamping business I have seen how ignorance of proper repair procedure can cause death by well intentioned people. Steering repair can have a similar outcome. The questions below may direct your decision whether this repair is for you.
Am I doing this repair safely or is it just to save money?
What is the type of material I'm working with in this job?
Do I know its physical properties?
How do I know if it has had any prior heat treatment?
Do I know how to prepare it correctly before welding?
What is the proper material for welding my part for a safe result?
Has my welding material been stored in the correct environment?
Is pre heat and post heat required for welding this piece?
Is it possible to heat it too much that it looses its integrity?
Am I really experienced in this type of welding?
Can I shape to final finish without leaving flaws like nicks or stress risers?
Can I make the ball round within a few thousands on an inch as the original?
Does this part or any partial section of the part require hardening?
Am I capable to harden and stress relieve correctly?
What does hardening even accomplish?
How would I know if any of this work is even needed?
I don't understand so should I revisit my past DIY work for unsafe practice?
Is this even legal to do?
Am I confident my Good intentions have the desired safe outcome?
Model "A" Fords is offline   Reply With Quote
Old 02-15-2023, 07:26 PM   #29
Pete
Pete's Avatar
When you think about it most of those questions could be applied to a back yard shadetree repair of anything.
It brings to mind the title of my favorite book. "Surgery At Home For Fun and Profit".
Old 02-16-2023, 08:13 AM   #30
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Yes, this list is SO true however I dare say most of the know-it-all hobbyists will not even take the time to read thru your list much less apply the wisdom in your list of questions to their own abilities.
FWIW, the comments/wisdom/advice on social media these days about what is the correct -or incorrect way to repair Model-As has changed my whole mind about trying to correct someone's wrong mindset with facts. Now, I just go back to the comedian Ron White's famous line of You Can't Fix Stupid, and just let some of these people show their ignorance and let the believers act on their advice.
Originally Posted by Pete View Post
When you think about it most of those questions could be applied to a back yard shadetree repair of anything. It brings to mind the title of my favorite book. "Surgery At Home For Fun and Profit".
Pete, that is funny!! I would expect to see some YouTube videos being produced in the near future to replace this Best Sellers List book.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
