11-20-2023, 08:42 AM | #1 |
A-5005-D Frame #6 Body Bolt Bracket Hole dimensions needed
I have a 160B Fordor in the shop that does not have the #6 Body Bolt Brackets installed. As luck would have it, I do not have a 5005-D frame to get the frame hole locations for the brackets, -and I only have the 5005-A and 5005-C prints which doesn't help with this either.
I have uploaded the back section of a frame print in hopes someone could give me the exact locations of the holes in the frame for those brackets using the rear running board rivet holes as a datum reference. TIA!! |
11-20-2023, 12:21 PM | #2 |
Re: A-5005-D Frame #6 Body Bolt Bracket Hole dimensions needed
