Old 04-08-2017, 11:10 AM   #1
meba49
Default 50 bell housing
Hi all. I have a bell housing and a 3sp f1 tranny for my 50 flathead v8. 10 inch clutch. Everything bolts up but the bell housing hits the pressure plate and won't go on. Would it go on over a 9.5 inch clutch/pressure plate? Mert
meba49 is offline   Reply With Quote
Old 04-08-2017, 12:00 PM   #2
JSeery
JSeery's Avatar
Default Re: 50 bell housing
How about posting a photo of your bell housing or at least some why of IDing it?
Old 04-08-2017, 02:19 PM   #3
meba49
This bell housing does not fit over my 50 f1 10 inch pressure plate. Do I need a 9.5 in pressure plate? Thanks. Mert
Old 04-08-2017, 02:40 PM   #4
JSeery
JSeery's Avatar
That is somewhat odd, where is it hitting, on the surface that bolts to the transmission?
Old 04-08-2017, 02:55 PM   #5
42merc
42merc's Avatar
The main shaft is not sliding into the pilot bushing / bearing.
Put the bell housing on, then the trans.
42merc is offline   Reply With Quote
Old 04-08-2017, 02:57 PM   #6
V8COOPMAN
V8COOPMAN's Avatar
That appears to be the stamped-steel Merc bell you have. To use the bigger clutch, you'll need the cast iron truck bell and starter plate like below. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-08-2017, 03:25 PM   #7
JSeery
JSeery's Avatar
Good input V8. So does the steel stamped one only clear a 9.5 pressure plate?
Old 04-08-2017, 03:40 PM   #8
rotorwrench
rotorwrench's Avatar
The stamped steel one should work. The cast iron one was designed for the 11-inch clutch and a 4-speed hogs head half bell. The Mercury cars use a 10-inch Borg & Beck and they have no issues. The 9 1/2-inch clutch plate won't work with the 1 3/8-inch 10-spline trans input shaft. I'd like to see the clutch to see what it is. 10-inch Long types do use the 1 3/8 10-spline disk but if it's something else???
Also, what type of oil pan are you using?
Old 04-08-2017, 03:43 PM   #9
flatjack9
flatjack9's Avatar
Mercury used a Borg and Beck pressure plate. They may have a lower profile.
Old 04-08-2017, 04:36 PM   #10
42merc
42merc's Avatar
The stamped steel Mercury bell will accept All 10" clutches, Long & Borg & Beck.
Very tight with an 11" clutch
Old 04-08-2017, 04:50 PM   #11
V8COOPMAN
V8COOPMAN's Avatar
IF this 8BA had an early flywheel on it, does anyone know if the clutch SURFACE on the early flywheel sits farther away from the crankshaft flange? That would be a situation (IF true) that MIGHT put the clutch too
close to the stamped bell. DD
T5 W/TORQUE TUBE
Old 04-08-2017, 10:59 PM   #12
George/Maine
George/Maine's Avatar
My guess the disk is on backwards, or the trans case is a early one.
I also would put the bell on first then the trans , you will see a lot better.
George/Maine is offline   Reply With Quote
