04-08-2012, 04:54 PM | #1 |
Autolite 2100 carb w/manual choke
City:
Justin
State:
Tx
Looking for a 2 bbl Autolite carb with manual choke. Several years would work (1966-1969). The air horn would need to have the vent hole in the top...NOT the solid top of some 2100's.
Does not need to be rebuilt. A tag number OR the number on the base (throttle side at the front) would be VERY helpful. Pictures would help a lot. Thanks for your time. |
04-11-2012, 11:09 AM | #2 |
Re: Autolite 2100 carb w/manual choke
I will be finishing up a rebuilt 68 or 69 manual choke, vent hole in top, today. It is a 1.23 venturi model, good for 351 or 390 engines. 53 jets are in place for a 351, but can change to 54 or 55 for use in the larger engine.
Mike, S. Oregon 46 Ford 1/2 ton, '62 Merc Meteor S33, '54 Ford 600 tractor, '64 Falcon Futura, 1960 Thunderbird |
04-18-2012, 01:20 PM | #3 |
Since posting my ad I have found a carburetor that will solve my problem. My main need was an air horn...mine was cracked. A kit should be here in a day or so and I am expecting a better running pickup. Have a great day! |
