04-21-2011, 01:58 PM | #1 |
1949-51 Intake Manifolds
Below are two manifolds. On the left is an 8RT & an 8CM on the right. QUESTION: What is the larger opening (plugged) on the 8RT used for? This is not present on the 8CM but the 8CM does have a fitting (NOT plugged) on the lower right of the manifold which is not present on the 8RT.
Are BOTH of these fittings for vacuum...when needed? |
04-21-2011, 02:03 PM | #2 |
Re: 1949-51 Intake Manifolds
Since the 8RT was a truck engine, I'd guess the large opening was vacuum for a brake booster. Vacuum assisted hydraulic brakes were fairly common on trucks of that era.
04-21-2011, 02:28 PM | #3 |
