Old 11-07-2019, 12:17 AM   #1
tomcarman
tomcarman's Avatar
Default 32 ford frame stamps
Hello,
I searched this topic and didn't find what I was looking for. I'm relatively new to posting a question so please excuse my ignorance. My question is simple. In 1932 if a Ford was a model B did the frame get a different stamp # than a model 18? I read where the # is located etc but no specifications on whether or not model B started with another number other than 18. Thank you much for your help.
tomcarman is offline   Reply With Quote
Old 11-07-2019, 02:52 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 32 ford frame stamps
Model 18 was the V8 and "B" the 4 cyl,so yes the number began with a "B"- 5000000.Here is a pic from the DeAngeles book of the engine numbers.I added this after Mart's post to hopefully help.
deuce lover is offline   Reply With Quote
Old 11-07-2019, 04:50 AM   #3
Mart
Mart's Avatar
First place I go to is here:
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
But I notice it doesn't list 4 cyl numbers.
4 cyl number info here: (32 stuff low down on the page).
http://www.fordgarage.com/pages/ABenginenumbers.htm
Mart.
Old 11-07-2019, 05:52 AM   #4
ronn
some 4 cylinders were also designated AB and the number
Old 11-07-2019, 08:15 AM   #5
DavidG
DavidG's Avatar
As ronn indicates, initially the prefix was 'AB', which was used until engine number 62,387 when the 'A' was eliminated from the prefix. (Engines destined for big truck chassis used ABB and BB prefixes in sequence with the rest of the fours. Those destined for RHD chassis had a 'F' added to the prefix, as in ABF, BF, ABBF, and BBF in sequence with the rest of the fours.)
Old 11-07-2019, 04:26 PM   #6
skidmarks
skidmarks's Avatar
Right had drive models, which side of the frame was the serial number stamped?
skidmarks is offline   Reply With Quote
Old 11-07-2019, 08:04 PM   #7
DavidG
DavidG's Avatar
It seems to depend on which RHD country the stamping took place. Of the examples I am aware of, the one South American RHD country of the period with assembly capability (Argentina) followed the Dearborn instructions and stamped them on the left side and I believe the United Kingdom-built RHD units were also stamped on the left side. The Commonwealth RHD countries which were Ford of Canada subsidiaries generally followed that instruction as well with Ford South Africa being a notable exception, at least some of the time, and there the stamping was on the right side of the vehicles that I've heard of.
Complete vehicle and SKD (slightly knocked down) kit vehicle exports from Canada and the U.S. to other RHD countries of the period such as Japan, Paraguay, Sweden and Uruguay, likely were also stamped on the left side.
Old 11-07-2019, 11:45 PM   #8
Tinker
Tinker's Avatar
Believe also a CA if Canadian. Certainly later yrs anyway. Model A out.
The "I" was also a "1" stamp early. don't think the stamps changed till around? I could look it up. 6,9, and 1/I. ...
Okay so, "the restorer" model a volume 56 - issue 1, has a editor question on stamp changes. Number change designs happened in February of 1931. Other sources say later but I'm going with this.
Vanpelts has the change but not sure about the yr change. Great site.
Not relative to what you are asking, but...
Old 11-08-2019, 08:30 AM   #9
DavidG
DavidG's Avatar
Can't say regarding Model A numbering, but Ford of Canada serialized its engines in relatively small batches (up to 10,000 in the case of V8s and up to 5,000 for fours) unlike Ford U.S. with each batch distinguished by another letter in the prefix as well as a 'C' leading off. For the subject '32 V8s, those were C18D and C18R and for the fours, CBG and CBQ. As with the U.S., an F was added for RHD.
Old 11-08-2019, 09:18 PM   #10
tomcarman
tomcarman's Avatar
Thank you all for your help.
Old 11-09-2019, 08:23 PM   #11
Tinker
Tinker's Avatar
Originally Posted by DavidG View Post
The six was changed at the same time as well.
Pretty neat ad/bulletin David. Thanks as usual!
Old 11-09-2019, 09:31 PM   #12
DavidG
DavidG's Avatar
It's from a period K. R. Wilson catalogue.
Old 11-09-2019, 09:51 PM   #13
Tinker
Tinker's Avatar
Never seen that one. Thanks for sharing!
