01-02-2016, 11:06 AM | #1 |
Starter solenoid needed
I am converting my 51 to 12 v. Can someone suggest a solenoid to use since there are only 6v solenoids for this year.
01-02-2016, 11:14 AM | #2 |
Re: Starter solenoid needed
The 6 volt solenoid is more than adequate. Because 6 volt requires more amps to do the same work it is built heavier inside than a 12 volt. If you can get one with the start button on the bottom, it's very handy. Napa should have one and their Echlin brand seems like a better product than some out there.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
01-02-2016, 11:14 AM | #3 |
I used the original one and never had a problem
01-02-2016, 11:15 AM | #4 |
1956 up Ford is a 12v solenoid... I've never messed with a 1951, so I don't know whether it's power to actuate, like the 56 Ford, or ground to actuate like my 1939 Ford.
Like others, I would use the 6v... Karl |
01-02-2016, 11:21 AM | #5 |
a little off topic, but sorta fits: the model T guys will put an old starter bendix spring in the wire to the starter for a big resistor to slow up the starter and keep the 12 volts from wrecking starter drives. anyone heard of that?
01-02-2016, 11:51 AM | #6 |
01-02-2016, 02:03 PM | #7 |
I dunno? My original early38 solenoid just took a dump after converting it to 12v in 1962.
Jack E/NJ |
01-02-2016, 07:40 PM | #8 |
I also lost a 6V solenoid. Mounted a '56 up solenoid insulated from ground, ran the POS wire to it and hooked the starter button to the frame of the solenoid. Been working great for over 31 years.
01-02-2016, 08:35 PM | #9 |
There are two meanings to 'POS' it can be confusing....
01-02-2016, 09:40 PM | #10 |
Yeah, but POS (alternate meaning) does not apply to our Fords.
01-02-2016, 10:11 PM | #11 | |
Search for the subject on this site or the Hamb... Karl |
01-02-2016, 11:22 PM | #12 |
I think I understand -
POS = Positive POS = Piece of Sculpture. |
01-03-2016, 07:45 AM | #13 |
I use the 12 vt. one called for in the 56 Ford. Works great.
01-03-2016, 11:12 AM | #14 |
Of course! But I was referring to the wire, which could have come from who knows where.....Rereading it doesn't make much sense. I do that sometimes. Sorry for any blasphemy I have committed.
01-03-2016, 11:58 AM | #15 |
Again, another vote for using the original. Still working after 26 years
01-03-2016, 12:11 PM | #16 |
I used an original nos 6 volt on my AV8, has worked great, but the push button did stick on me once.
01-03-2016, 12:38 PM | #17 |
I used this 12V solenoid when I converted my 40 to 12V. They are available at any auto parts place. I by passed the OEM starter button and installed a push button starter switch under the dash as a theft deterent. The OEM buttom is not in use.
http://www.ebay.com/itm/Starter-Sole...-/261275584330 Last edited by 19Fordy; 01-03-2016 at 01:09 PM. |
01-03-2016, 02:21 PM | #18 | |
Karl |
01-03-2016, 07:07 PM | #19 |
I like that idea! LOL
02-05-2021, 04:43 PM | #20 |
I converted my '39 Ford truck from 6V positive ground to 12V negative ground. Everything worked fine when I had a temporary control panel (start button, on/off switch, etc.). In this temporary set-up, I used a 12V starter solenoid. When I wired everything permanently, I used the original 6V solenoid. Does it matter that this solenoid was originally used in a positive ground system? The problem I encountered is when I turned the switch on, the wiring immediately got really hot. I turned it off before anything burned up. A bench check of the solenoid with a 12V battery prior to installation was good. Any suggestions?
Thread Tools | |
Display Modes | |
