07-27-2013, 10:06 PM | #1 |
Air Cleaners
I've go my three 97's set up and all is running well. Rebuilt by Uncle Max. Used a unisyn to balance them out. Great response, starts easily, plugs look good, etc. My question is: When I put on the air cleaners there is a noticable change in engine RPM. I'm using the bonnet type air cleaners with louvers and K&N filter elements. My concern is that this will cause a rich running condition. Any suggestions as to which type of air cleaners are best to run. Frog Mouth, Velocity Stacks, etc. Thanks for you inputs.
07-28-2013, 08:46 AM | #2 |
Re: Air Cleaners
Someone, in the past, posted that a 4" tall air filter (K/N) is needed. Smaller are too restricted. This is from memory.
07-28-2013, 05:24 PM | #3 |
Re: Air Cleaners
Thanks Tony, I'll check them out. I can't believe that 140 people viewed this post and only one (You) had a suggestion. Thanks again.
07-28-2013, 06:17 PM | #4 |
Re: Air Cleaners
I'll wager that if you send a PM to Walt Dupont, and asked nicely, he'd send you the part number for the tall K&N aircleaners.
07-28-2013, 07:04 PM | #5 |
Re: Air Cleaners
Personally I cant see how a filter that small and so close to the opening of carb can be any good , You've seen it yourself. An airfilter on a carb if correct so show no noticable difference either on or off.
07-28-2013, 08:03 PM | #6 |
Re: Air Cleaners
http://www.fordbarn.com/forum/showth...ght=air+filter http://www.knfilters.com/search/prod...id=526551&rw=1 Last edited by Tony, NY; 07-28-2013 at 08:07 PM. Reason: added link |
07-29-2013, 08:59 AM | #7 |
Re: Air Cleaners
Thanks to all who replied and thanks to Uncle Max for some great carb rebuilding.
07-29-2013, 01:27 PM | #8 |
Re: Air Cleaners
If the air cleaner makes a difference on or off, the filter area is way too small.
Figure 3 to 4 times the venturi area to be safe. It also depends on the filter media. (paper,foam,etc) |
07-29-2013, 01:44 PM | #9 |
Re: Air Cleaners
If you use the open side 4" air cleaner there is one from an Onan engine much taller not to expensive but works Wix 42362 Laurie
Thread Tools | |
Display Modes | |
