Old 05-23-2021, 11:42 AM   #1
alexiskai
alexiskai's Avatar
Default Example plug wires for Winfield head
Awhile back I asked about spark plug connectors for use with a Winfield head. The Winfield relocates the plugs between the valves, rather than over the intake. This means that the 1 and 4 plugs are now too far away from the distributor for the stock connectors to bridge, and the 3 plug is uncomfortably close to the spark advance rod. After some trial and error, I came up with this solution. This uses Model T plug wire and terminals.
I think it came out pretty well, looks period and does the job. I did end up putting a bend in the spark control rod to move it farther away from the #3 plug, and I'm also going to wrap a little electrical tape around it just to be safe.
Old 05-23-2021, 11:47 AM   #2
ahirt
Default Re: Example plug wires for Winfield head
Neat!!
ahirt is offline   Reply With Quote
Old 05-23-2021, 03:01 PM   #3
shew01
shew01's Avatar
Nice job. [emoji106]
Old 05-23-2021, 06:24 PM   #4
Jim Baskin III Pa.
Jim Baskin III Pa.'s Avatar
That is the best I have seen yet. Very ingenious.
Jim Baskin III Pa. is offline   Reply With Quote
Old 05-23-2021, 06:32 PM   #5
burner31
burner31's Avatar
Looks very nice, be proud
Keith
Shawnee OK
'31 SW 160-B
Old 05-23-2021, 09:03 PM   #6
Mountain Dew
Mountain Dew's Avatar
Looks neat! The Brillman Company sells the braided high tension wire and terminals. You could make a coil wire to match.
Mountain Dew is offline   Reply With Quote
Old 05-24-2021, 10:22 AM   #7
katy
katy's Avatar
Instead of wrapping the spark control rod w/electrical tape, how about painting it w/liquid electrical tape? Might look a bit better.
https://www.homedepot.com/p/Gardner-...-400/100119178
