Old 06-17-2018, 03:20 PM   #1
john in illinois
john in illinois's Avatar
Default Gas leaking from float bowl
I have a 97 that leaks internally from float bowl. It is not evaporating,and with the air horn off I can watch it drop. Fuel level seems correct. I have had different power valves in it,so I do not think it is pv leaking.
Could the accelerator pump check valve be the cause? It pumps ok and the carb idles fine,but has always been hard to tune. I knew it was always low on gas when the rear carb was full,but did not realize it leaked so quickly. New 97 with
1500 miles on it. I do not want to send it off to Max if I can fix it.
John
john in illinois is offline   Reply With Quote
Old 06-17-2018, 10:30 PM   #2
fordwife
Default Re: Gas leaking from float bowl
Bad gasket or wrong gasket on power valve?
fordwife is offline   Reply With Quote
Old 06-18-2018, 12:17 PM   #3
cmbrucew
cmbrucew's Avatar
Here is an installation guide from the internet.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 06-18-2018, 12:19 PM   #4
Seth Swoboda
Seth Swoboda's Avatar
Is it leaking from the accelerator pump hole on the top of the carburetor?
Old 06-18-2018, 04:06 PM   #5
john in illinois
I found it today. Front power valve was leaking. It was either defective or not tight enough. Replaced it with anew one. Bench tested it and no leakdown.
Ready for a test drive tomorrow.
John
